Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 64
  1. #16
    17,625
    Quote Originally Posted by theniels17 View Post
    i can also not give this b_permission_modify_power_ignore
    Don't try to assign that permission to a non Query Admin Group!!!!!
  2. #17
    April 2016
    I accidently removed the entire Server Admin group going through the permission and now do not have access to anything anymore.
    The server I'm running on Nitrous Network has a thing to create server tokens but now that the server admin group is removed I can't create a toke of this one anymore.
    How do I recreate the server admin group now without having to completely recreate the server?
    What do I do when ServerQuery login is greyed out in TS3?
    Last edited by dante696; April 25th, 2016 at 08:44 AM. Reason: merged 2 posts and threads
  3. #18
    17,625
    Quote Originally Posted by nex86 View Post
    You use the serveradmin login that was give on firs server start.
    Your own Query account would not be able to fix this due missing permissions
  4. #19
    October 2013
    11
    Question permission removed by mistake
    1. So I removed i_channel_permission_modify_power by mistake on my admin group. and when I try to add the permission I get this error insufficient permission modify power. how can I add it again ?
    2. when I try to edit a channel and add modify power higher than 0 I get this error: insufficient client permissions (failed on i_channel_needed_permission_modify_power). Is this related ? is it because I removed the permission by mistake ? how can I reset this ?
    3. is it possible to reset the admin group ?
    Please help
    Thanks
  5. #20
    October 2014
    0
    Teamspeak 3 Permissions
    I host a TS3 server on my home computer and seem to have gotten the permissions for the Server admin groups messed up beyond repair (due to no longer having permissions to change the groups). I would like to restore the permissions and am wondering how to use the "Serveradmin" and password that i was given when I first started the server in order to restore these permissions?
    Thanks in advance!
  6. #21
    May 2016
    The Netherlands
    32
    How to use Server Query
    Once logged in on the command line, the command permreset will reset all permissions.
  7. #22
    June 2016
    Could fault
    This problem could be because you chose the wrong one certain command on the server
  8. #23
    October 2014
    0
    Error with PuTTY
    I am getting this error when trying to reset the perms on my ts server. Any ideas? (Using Putty)
    TS3
    Welcome to the TeamSpeak 3 ServerQuery interface, type "help" for a list of commands and "help <command>" for information on a specific command.
    login serveradmin Password
    error id=0 msg=ok
    permreset
    error id=1024 msg=invalid\sserverID
    Last edited by dante696; June 10th, 2016 at 08:31 AM. Reason: moved to thread where use came from
  9. #24
    17,625
    Quote Originally Posted by m88vnn View Post
    What are you reffering to?
  10. #25
    6,056
    Quote Originally Posted by Alexkellam View Post
    TS3
    error id=0 msg=ok
    permreset
    you need to select the virtual server you want to perform a permission reset on first. This can be done with the "use" command. For example: "use port=9987" would choose the first server on port 9987 to run any subsequent commands on.
  11. #26
    June 2016
    Problem with permissions
    Hi!
    First of all sorry if my english is bad, i am spanish :P
    Well i was trying to create a new spacer and an error comes up:
    "insufficient client permissions (failed on i_channel_min_depth)"
    So i try editing the client permissions(me) but i when i try to add the
    permission another error comes up: "insufficient permission modify power"
    And the thing is, i am the admin of the server lol. What can i do?
    Thanks for your time!
  12. #27
    17,625
    Grant on i_channel_min_depth is missing.
    Please reset your admin group in the ServerQuwty with command severgroupcopy.
    Explained here http://forum.teamspeak.com/threads/1...p-is-screwd-up
  13. #28
    June 2016
    query server admin permissions
    Hi
    when i log via putty and login as server query admin and try to change permissions of server admin group it says not enough client permissions
    screen:
    failed_permid=162 is that permission im trying to change
    somebody set on server that server admin cant remove other server admins from group
    is there any solution to solve this permissions problem?
  14. #29
    17,625
    You fail on permission i_group_needed_modify_power.
    Your i_group_modify_power is not high enough to add permissions into the Server Admin group.
    Following is danger and you better make a backup of your database!
    Are you really logged in wiht the account serveradmin?
    In case of: You may raise i_group_modify_power in sgid=2
    //Edit
    Better reset your Server Admin group as explained in next post or post #2.
  15. #30
    6,056
    162 is i_group_needed_modify_power.
    try
    servergroupaddperm sgid=6 permid=162 permvalue=75 permnegated=0 permskip=0
    first.
    If that fails you can try:
    servergroupcopy ssgid=3 tsgid=6 name=Server\sAdmin type=1
    to reset the ServerAdmin group.
  1. Replies: 18
    Last Post: May 20th, 2017, 08:00 PM
  2. Server permissions are screwed up
    By tomjx in forum Permission System
    Last Post: November 22nd, 2016, 07:28 AM
  3. Replies: 4
    Last Post: June 6th, 2016, 09:48 PM
  4. Changed Group Modify Power of Server Admin Group
    By BLack RIder in forum General Questions
    Last Post: April 13th, 2014, 12:45 PM
  5. Replies: 1
    Last Post: January 11th, 2014, 05:10 PM
