Results 46 to 60 of 60
  1. #46
    17,382
    Modifying the database is not supported from us.
    Supported is to use the ServerQuery with login serveradmin to add missing permissions.
    Se post #2 for more details.
  2. #47
    October 2017
    Server Adm Problem
    Hi, I have a problem with my server adm, I have enabled these two permissions on i_group_modify_power and i_group_needed_modify_power, now I can not modify the group, it says the indicator is enabled for this group, please help me!
  3. #48
    4,265
    You destroyed your server group. If that is your own instance, copy the Server Admin group template over that group via query. If that is not your instance, ask the hoster to do that.
  4. #49
    November 2017
    General Filetransfer Permissions Question
    I just got into teamspeak, and rented a server for my friends and I. We were trying to figure out the file transfer system. They were unable to do it, so I tried modifying the permissions for the file transfer. Unfortunately, I changed the value and grant for me (server admin) to 0 as well. Now, I can't even edit the permissions for file transfer. Is there any way to reverse this? Also, my friends are telling me they're unable to change channels? I'm quite new to Teamspeak, so I don't know much!
  5. #50
    February 2017
    insufficient group and permission modify power
    I am ServerAdmin on the server running on my PC. However, I am unable to modify certain certain permissions. I'm being told: " insufficient group modify power", and "insufficient permission modify power". And if I try to change any of those parameters, I, of course, get the same errors. Help is appreciatet.
    Last edited by dante696; December 27th, 2017 at 07:59 PM. Reason: merged + lack of information
  6. #51
    February 2018
    Reset Permissions
    One of my server admins must have done something because I can't edit client permissions. I've downloaded Putty but that keeps giving me an error every time I login (I'm sure I used the right login and password). I also tried YaTQA and that gives me an error as well. I'm at a loss and extremely frustrated. Any help is really appreciated.
    PS: I've looked up several previous threads about this and nothing I've seen has worked for me. Also the attachment is the error message from YaTQA.
  7. #52
    March 2018
    Remove grants permmision
    my problem is that I no longer have files for this server that I own no longer rights or as the owner of this server and I do not know what else to do please for help or I prefer to cancel the server I attach a problem picture and thank you for the help in advance .. and I'm sorry if I break some posting rules ..Click image for larger version.
  8. #53
    17,382
    The server is lost in case you do not own the Query access and serveradmin login or at least one user with client permissions set to set Grant(s) back.
    Only the owner or person with access can fix this in that case.
  9. #54
    March 2018
    Removed "server admin" server groups
    I removed the admin server group so I can't generate a new priviledge key. I tried connecting to the server with putty but I dont have the serverquery username or password.
    Is there any way I can reset my server to default permissions?
  10. #55
    17,382
    There is no way around the ServerQuery, when you have no backup of your database or a similar server group where you are member.
  11. #56
    August 2018
    Removed my self from admin, with Server Quarry disabled! need help ASAP!
    So basically, i removed rights to use server quarry, i home host the server is there some file i can edit and manually create a new admin token key, or a file where i can put my ID and set my self as admin agian?
  12. #57
    November 2018
    No privileges On MY OWN SERVER
    So I wanted to deleted all my groups on my teamspeak server. Which I skip over ever warning message when deleting the server groups and now I cant add nor change groups. But I can still kick from channel, kick from server. Is there anyway I can fix it to where I can add server groups, create them again, w/o creating an entire new server as now it will not let me.:|
  13. #58
    January 2019
    Sever Group mistake
    i own a ts3 server and i accidentally set the "Group Modify Power" to 74 on the Owner group which only i have and none of the groups have the "Group Modify Power" enabled so if i enable it, i will only have permision to set it as 74. what can i do to change the "Group Modify Power" for the Owner group back to 75? Because now i cant edit anything to be higher than 74
  14. #59
    January 2019
    Server group help. i messed up
    So i set this as 74 by accident (on the highest ranked server group) and now i can't change many things. How do i set it back to 75? Whenever i try to set it to 75 or more, it gives me an error
  15. #60
    August 2017
    Ukraine
    9
    If you rent a server, contact technical support to restore the backup or change permission via query.
  1. Replies: 4
    Last Post: June 6th, 2016, 10:48 PM
  2. Changed Group Modify Power of Server Admin Group
    By BLack RIder in forum General Questions
    Last Post: April 13th, 2014, 01:45 PM
  3. Replies: 1
    Last Post: January 11th, 2014, 06:10 PM
