Results 1 to 9 of 9
    December 2015
    I can not hear other users when i talk
    Hi, in TeamSpeak 3 i use - Push to Talk button.
    When i want speak i press button and start talk, so when speaking at the same time another player so he muted and no hear him.
    How do I stop talking and I let the button so all can hear normally again.
    You do not know how this option can be turned off?
    Thanks
    18,015
    Try to run the client without Echo reduction and/or cancelation.
    This setting can be found under Tools -> Options -> Capture
    January 2016
    Can Barely Hear Other Client's Voices...
    Hello. I've been having some trouble with Teamspeak recently. When I am talking to other people, their voices cut in and out and I cannot hear everything they are saying to its full extent. I have already tried uninstalling and reinstalling TS and am not sure what else to do. I am not getting any packet loss, the only things I can think of are to upgrade to Windows 10 or maybe it has something to do with running other programs that produce sounds in the background. Please help, I've been having this problem for two months.
    Thanks
    July 2016
    can't hear other poeple voice when speaking
    I use push-to-talk for my capture setting. When push the hotkey to activate my mic i no longer can hear the voice of other people. How can i fix this?
    18,015
    Sounds like our echo cancelation.
    In case of:
    Just disable or change the value for "Echo reduction" to get this solved.
    This feature be found under Settings -> Options -> Capture
    August 2016
    Problem with sound of Teamspeak
    Today I met a Reccurent worries over Teamspeak 3. Whenever I speak I do not hear people talking at the same time as me, if I did not talk I hear correctements ... Can you help me?
    Thank you & sorry for this rough translation , google is your friend !
    Cordially.
    Last edited by dante696; August 10th, 2016 at 10:15 AM. Reason: merged, explained in post #2 or #5
    January 2017
    Teamspeak 3 reverse priority speaker?
    I'm having a issue since the new update when ever i talk over someone or at the same time it fades there voice down like when they have priority speaker but it's the opposite it turns them down for me... any ideas how to fix?
    I used to be pretty good with TS until this new update so any help would be greatly appreciated... it's really annoying now! haha
    Cheers
    Withas
    18,015
    It's enabled "Echo reduction" and the value in "Echo reduction reduces playback by:" causing that.
    You can find these settings in your Capture profile under Tools -> Options -> Capture.
    January 2017
    Turning echo reduction off didn't work
    Hello i turned echo reduction off and it still does not work, when ever i talk it sounds like a radio turning on and off then when i talk it totally kills everyone else's voice so i can not hear them what so ever!! unless i stop talking and the sound happens again...
    Please help i have turned settings off and on nothing works i have re installed and changed my settings on my pc and nothing works with TS.
  1. [Resolved] Can't hear others or can't talk to users.
    By approxx in forum Windows
    Last Post: December 29th, 2016, 01:56 AM
  2. Replies: 1
    Last Post: April 4th, 2014, 01:13 AM
  3. Replies: 0
    Last Post: February 17th, 2012, 12:58 PM
