Results 1 to 10 of 10
    May 2013
    TS3ANetwork Error -3
    last night the following error appears in our serverlog and all servers were not reachable for 30 minutes. What could this mean?
    TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    Thanks for support
    17,920
    Your server had a problem resolving dns addresses.
    This is what you have to fix.
    January 2016
    help with error please!
    Hi, im run my ts3 on centos 6.7 64 bits
    and found this error in logs that repeats constantly, I think make crash the server randomly, and nothing found on google about this issue
    thanks ind advance!
    2016-01-18 15:45:11.196305|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 15:45:11.196723|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 15:45:11.197164|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 15:45:11.197575|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 15:45:11.197993|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 15:45:11.198406|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 15:45:11.198869|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 15:45:11.199288|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 15:45:11.199326|ERROR | | | Could not open/bind UDP connection on MY.SERVER.IP.ADDRESS for weblist. Using default
    2016-01-18 15:45:11.251681|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 15:55:11.277531|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 16:05:11.322520|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 16:15:11.341426|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 16:25:11.361488|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 16:35:11.459080|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 16:45:11.548800|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 16:55:11.526352|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 17:05:11.653036|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 17:15:11.659061|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 17:25:11.718254|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2016-01-18 17:35:11.683774|ERROR | | | TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    17,920
    The server does not crash. It shuts down, because it can not validate the licene anymore.
    Your server machine has problems to resolve DNS adresses.
    August 2014
    7
    TS3ANetwork temporary failure in name resolution Error: -3
    Hey guys my teamspeak server crashed this afternoon and i cant find much on my problem at all. It can't resolve the hostname. I am not an expert and can do basic trouble shooting/installing teamspeak and googling but i cant find much on this.
    I am running centos 7 32 bit
    [[email protected] teamspeak3]# ./ts3server_minimal_runscript.sh start inifile=ts3server.ini
    2017-01-24 20:25:02.948447|INFO    |ServerLibPriv |   |TeamSpeak 3 Server 3.0.13.6 (2016-11-                      08 08:48:33)
    2017-01-24 20:25:02.948848|INFO    |ServerLibPriv |   |SystemInformation: Linux 2.6.32-042st                      ab120.16 #1 SMP Tue Dec 13 20:58:28 MSK 2016 x86_64 Binary: 32bit
    2017-01-24 20:25:02.948879|WARNING |ServerLibPriv |   |The system locale is set to "C" this                       can cause unexpected behavior. We advice you to repair your locale!
    2017-01-24 20:25:02.948901|INFO    |ServerLibPriv |   |Using hardware aes
    2017-01-24 20:25:02.949468|INFO    |DatabaseQuery |   |dbPlugin name:    SQLite3 plugin, Ver                      sion 3, (c)TeamSpeak Systems GmbH
    2017-01-24 20:25:02.949731|INFO    |DatabaseQuery |   |dbPlugin version: 3.11.1
    2017-01-24 20:25:02.949922|INFO    |DatabaseQuery |   |checking database integrity (may take                       a while)
    2017-01-24 20:25:02.969061|WARNING |Accounting    |   |Unable to find valid license key, fal                      ling back to limited functionality
    2017-01-24 20:25:06.886008|INFO    |              |   |Puzzle precompute time: 3896
    2017-01-24 20:25:10.664211|INFO    |FileManager   |   |listening on 192.168.53.144:14402
    2017-01-24 20:26:30.741464|ERROR   |              |   |TS3ANetwork::ResolveHostName failed error: -3 (Temporary failure in name resolution) 11
    2017-01-24 20:26:30.741514|ERROR   |              |   |Could not open default UDP connection for weblist
    2017-01-24 20:26:30.747202|INFO    |VirtualServer |1  |listening on 192.168.53.144:14401
    2017-01-24 20:26:30.747318|INFO    |CIDRManager   |   |updated query_ip_whitelist ips: 127.0.0.1/32, ::1/128,
    2017-01-24 20:26:30.747394|INFO    |Query         |   |listening on 192.168.53.144:14403
    ^C2017-01-24 20:26:50.322725|INFO    |ServerMain    |   |Received signal SIGINT, shutting down.
    2017-01-24 20:26:50.323038|INFO    |VirtualServerBase|1  |stopped
    My ts3server.ini file is:
    machine_id=
    default_voice_port=14401
    voice_ip=192.168.53.144
    licensepath=
    filetransfer_port=14402
    filetransfer_ip=192.168.53.144
    query_port=14403
    query_ip=192.168.53.144
    query_ip_whitelist=query_ip_whitelist.txt
    query_ip_blacklist=query_ip_blacklist.txt
    dbplugin=ts3db_sqlite3
    dbpluginparameter=
    dbsqlpath=sql/
    dbconnections=10
    logpath=logs
    logquerycommands=0
    dbclientkeepdays=30
    logappend=0
    query_skipbruteforcecheck=0
    Probably has something to do with the host file but I am not sure what to edit:
    127.0.0.1 localhost.localdomain localhost localhost4.localdomain4 localhost4
    # Auto-generated hostname. Please do not remove this comment.
    192.168.53.144 jeemgu
    ::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
    Normally i launch the server with:
    ./ts3server_startscript.sh start inifile=ts3server.ini
    How do i fix this? If you have a any clue please help
    August 2014
    7
    Thanks, I never claimed to be unsure what the problem is. I am unsure how to fix it.
    I think your post really helps me fix it
    August 2014
    7
    Quote Originally Posted by Richi View Post
    thanks ind advance!
    Thanks man truly made me understand the problem what IP it couldn't resolve. Thanks!
    August 2014
    7
    Yeah it said stopped but when not running minimal_runscript it doesn't stop on its own it keeps running into the same error every 10 minutes.
    I know I probably have to clarify a IP address in etc/hosts but I don't know which IP and to what I should be linking it. It ran without problems for 3 months.
    17,920
    The fix isn't to add IP's into the host file.
    The fix is to make sure your machine can resolve DNS addresses.
    1. Make sure the needed ports for the server arn't blocked in a firewall or router
    https://support.teamspeakusa.com/ind...k-3-server-use
    2. Try another nameserver when your old does not work anymore (your part to google how to do it)
    https://www.centos.org/forums/viewtopic.php?t=8093
    Last edited by dante696; January 25th, 2017 at 08:28 AM. Reason: added missing word
    August 2014
    7
    1. Make the needed ports for the server arn't blocked in a firewall or router
    I will go over this all again thanks.
    I check the nameserver I am using Google's first and secondary dns server.
  1. Server Error - TS3ANetwork::Recv failed error: 10054
    By Ruvenzori in forum Server Support
    Last Post: January 19th, 2013, 04:18 AM
  2. TS3ANetwork::Connect failed error: 110
    By Crunk_Bass in forum Linux / FreeBSD
    Last Post: August 2nd, 2011, 03:27 PM
  3. TS3ANetwork::Send failed error: 13
    By xEvAngelx in forum Linux / FreeBSD
    Last Post: August 12th, 2010, 06:14 AM
  4. [Solved] Error TS3ANetwork::Connect failed error: 10022
    By sanlostsoul in forum Permission System
    Last Post: April 10th, 2010, 01:41 PM
