Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    August 2013
    Deleted Query Group (Guest or Admin) or removed serveradmin form Query Admin group
    So one of my admins deleted the Server Query Admin Group, now I cant use the remote Administration tools
    Any Idea how to solve this problem?
    Thanks for you help
    August 2013
    530
    this is one of the reasons why you should NEVER add ANY regular client (meaning a non-query client) to the Admin Server Query group. It is just too easy to damage your database beyond repair and we do not give any support, if there has been messing around with the Query Groups.
    You will have to start from scratch with a new database. From now on please do not touch the Admin Server Query group. There is absolutely no reason why a regular client should be in there.
    January 2014
    i've deleted the serveradmin query account... Can i restore it?
    resolved thank
    January 2016
    Problem Deleted Query Group (Guest or serveradmin)
    Hey there,
    I have a pretty big problem and do not know how to fix it. Yesterday between the web panel that I have installed to handle the TeamSpeak, and inadvertently delete one of the ts3 server group: Guest Query.
    From that moment to access the web control panel to manage ts3 use, I do not detect any permission. Every time I go to one of the TS3 that I have created, I do not detect any of the permits had. I was wearing query the server admin. Need to know if there is any way to get back Permissions query server admin and set all permissions again as they were, without having to reinstall the TS3, I need urgent help.
    thanks
    18,020
    Using the Query group for clients is not supported
    You must start your server from scratch to get this fixed. There is no other way.
    For anyone else having the same problem, but not using a query group for clients:
    Use a backup of your database or start from scratch to get this fixed.
    February 2012
    572
    The Teamspeak server should prevent adding/deleting forbidden group memberships and prevent deleting essential groups, so this kind of problem cannot occur in the first place.
    October 2012
    23
    Not able to login with Server Query Admin even after changing password
    Hey Guys
    I installed my TS3 Server today and deleted the "Normal" Server Group which I want back now.
    I searched through google and found out that I can use "permreset" when I'm logged in as Server Query Admin.
    Now the first problem was that when I set up the teamspeak server my log didn't tell me of a password for the Server Query Admin.
    That's the initial log I got:
    2016-01-14 10:53:04.702370|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.11.4 (2015-08-18 13:30:34)
    2016-01-14 10:53:04.702951|INFO    |ServerLibPriv |   | SystemInformation: Linux 3.2.40 #5644 SMP PREEMPT Wed Oct 28 12:35:52 CST 2015 i686 Binary: 32bit
    2016-01-14 10:53:04.705622|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2016-01-14 10:53:04.705892|INFO    |DatabaseQuery |   | dbPlugin version: 3.6.21
    2016-01-14 10:53:04.707331|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2016-01-14 10:53:04.804260|INFO    |SQL           |   | db_CreateTables() tables created
    2016-01-14 10:53:06.697069|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2016-01-14 10:53:21.881900|INFO    |              |   | Puzzle precompute time: 15069
    2016-01-14 10:53:21.883410|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2016-01-14 10:53:21.908190|INFO    |VirtualSvrMgr |   | executing monthly interval
    2016-01-14 10:53:21.908953|INFO    |VirtualSvrMgr |   | reset virtualserver traffic statistics
    2016-01-14 10:53:23.095677|INFO    |VirtualServer |  1| listening on 0.0.0.0:9987
    2016-01-14 10:53:23.097824|INFO    |VirtualServer |  1| client 'server'(id:0) added privilege key for servergroup 'Server Admin'(id:6)
    2016-01-14 10:53:23.098055|WARNING |VirtualServer |  1| --------------------------------------------------------
    2016-01-14 10:53:23.098219|WARNING |VirtualServer |  1| ServerAdmin privilege key created, please use the line below
    2016-01-14 10:53:23.098380|WARNING |VirtualServer |  1| token=<<secretToken>>
    2016-01-14 10:53:23.098539|WARNING |VirtualServer |  1| --------------------------------------------------------
    2016-01-14 10:53:23.164690|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2016-01-14 10:53:23.166194|INFO    |Query         |   | listening on 0.0.0.0:10011
    Because I've never worked with Server Query I checked in client with my Server Admin-User under Tools --> ServerQuery Login and set up a new account. I was able to login but my rights aren't sufficent to use permreset.
    Question #1: How can I delete this account, because it's useless and I don't want it to use or to be used again?
    Now that I didn't got a Server Query Admin password I used Google again and found this Tutorial on how to change the password: https://support.teamspeakusa.com/ind...admin-password
    I read through it and did it and my server says:
    2016-01-15 01:07:14.371713|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.11.4 (2015-08-18 13:30:34)
    2016-01-15 01:07:14.372313|INFO    |ServerLibPriv |   | SystemInformation: Linux 3.2.40 #5644 SMP PREEMPT Wed Oct 28 12:35:52 CST 2015 i686 Binary: 32bit
    2016-01-15 01:07:14.375068|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2016-01-15 01:07:14.375336|INFO    |DatabaseQuery |   | dbPlugin version: 3.6.21
    2016-01-15 01:07:14.376597|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2016-01-15 01:07:14.469523|INFO    |ServerLibPriv |   | updated server query admin password
    2016-01-15 01:07:14.478542|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2016-01-15 01:07:28.233456|INFO    |              |   | Puzzle precompute time: 13680
    2016-01-15 01:07:28.235028|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2016-01-15 01:07:28.446444|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2016-01-15 01:07:28.447877|INFO    |Query         |   | listening on 0.0.0.0:10011
    2016-01-15 01:08:49.103417|INFO    |Query         |   | query from 1 192.168.1.7:57494 attempted to login with account "serveradmin" and failed!
    Well the last line tells it all...
    Why can't I still login to use my 100 powers via Server Query?
    Thanks in advance!
    ~ R3dCr0ss
    December 2004
    RF
    3,004
    http://forum.teamspeak.com/threads/7...ge-key-(Token)
    But I'm afraid that would not be enough and you're in for a total server reinstall.
    October 2012
    23
    Hi ANR Daemon,
    thanks for your answer. I read the whole thread but there's nothing that really helps me...
    I know how to use the Server Query but I never saw a log saying that there was a Server Query Admin login created.
    I even managed to change the password but still can't login.
    Is it possible and if yes HOW is it possible that there was no Server Query Admin created?
    18,020
    1. A permreset can not be perfomred from a custom Query login as long it does not own the permission b_virtualserver_permission_reset (which is the default disbaled by default).
    This needs to be done from the ServerQuery Admin with login serveradmin.
    2. The server log never prints the password to the log.
    You need to write it down direcly after first start Or change it afterwards. We have threads for this.
    We have an FAQ entry for this already.
    https://support.teamspeakusa.com/ind...-query-account
    3. There was 100% a Query Admin created on your first server instance start, when the DB was generated.
    Your server would not work properly without it.
    October 2012
    23
    Thank you for you answer, Dante
    I used the link you provided and started the ts3 server with the minimal runscript.
    It says that the server query admin password was changed but I can't stop and start the server again. It's still running and says no instance found when I want to restart or stop it.
    I tried the new password without restarting the server and it still doesn't work... I'm getting really pissed now.
    Why the hell is it so hard to get this damn password, that's my server and I can't access the teamspeak with the powers I want?!
    18,020
    Show us the complete commands you have used to start your server and to login into that server
    Should be:
    ./ts3server_minimal_runscript.sh serveradmin_password=test1234
    or
    ./ts3server_startscript.sh start serveradmin_password=test1234
    and on Telnet/Putty:
    login serveradmin test1234
    use 1
    permreset
    There is no need to restart the server and i do not understand what you mean with instance.
    Read your server log if the server does not start again. It will tell you exactly what is wrong.
    October 2012
    23
    Thanks for your answer, Dante.
    In your link (https://support.teamspeakusa.com/ind...-query-account) it says: Upon starting up the server, the serveradmin password will be changed. Now please stop the server again and start it regularly (i.e. Linux users use the regular startscript, Windows users delete the shortcut created above and run exe file or your usual shortcut).
    That's why I wanted to restart the server.
    I stopped my server:
    2016-01-15 12:59:09.334682|INFO    |VirtualServerBase|  1| stopped
    Now again, I open up my terminal in the directory 'teamspeak3-server_linux-x86' and type in:
    sh ts3server_startscript.sh start serveradmin_password=test1234
    Terminal says:
    BusyBox v1.16.1 (2015-10-28 13:24:34 CST) multi-call binary.
    Usage: readlink FILE
    Display the value of a symlink
    Starting the TeamSpeak 3 server
    TeamSpeak 3 server started, for details please view the log file
    Log says:
    2016-01-15 13:00:48.998867|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.11.4 (2015-08-18 13:30:34)
    2016-01-15 13:00:48.999524|INFO    |ServerLibPriv |   | SystemInformation: Linux 3.2.40 #5644 SMP PREEMPT Wed Oct 28 12:35:52 CST 2015 i686 Binary: 32bit
    2016-01-15 13:00:49.002234|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2016-01-15 13:00:49.002508|INFO    |DatabaseQuery |   | dbPlugin version: 3.6.21
    2016-01-15 13:00:49.003919|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2016-01-15 13:00:49.096023|INFO    |ServerLibPriv |   | updated server query admin password
    2016-01-15 13:00:49.104936|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2016-01-15 13:01:02.150977|INFO    |              |   | Puzzle precompute time: 12971
    2016-01-15 13:01:02.152137|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2016-01-15 13:01:02.362593|INFO    |VirtualServer |  1| listening on 0.0.0.0:9987
    2016-01-15 13:01:02.363430|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2016-01-15 13:01:02.364806|INFO    |Query         |   | listening on 0.0.0.0:10011
    Teamspeak's up and running.
    Now I open up KiTTY:
    Hostname: 192.168.1.10
    Port: 10011
    Connection Type: Telnet
    {Enter}
    KiTTY says:
    TS3
    Welcome to the TeamSpeak 3 ServerQuery interface, type "help" for a list of commands and "help <command>" for information on a specific command.
    I type in:
    And KiTTY says:
    error id=520 msg=invalid\sloginname\sor\spassword
    I don't get what I'm doing wrong here...
    October 2012
    23
    Dante, I love you!!
    Just as I saw the image I remembered that I deleted this line because I thought that this are only the connected clients and after the first login fail to serveradmin I thought, since I wasn't ever in with this user it doesn't need to be in that table and deleted it >.<
    I did what you wrote. After starting the server to create a new database it didn't send me the newly generated serveradmin password but I stopped it anyway, started it with changing password and was able to login after...
    Now the followup question:
    What do I have to do in my old database to "recreate" the serveradmin user?
    And the 1st Question in my first post:
    How can I delete the Server Query Login I created with my 75 powers?
    Because I have no need to login to the query with other powers than 100...
    Thanks again!
    18,020
    Quote Originally Posted by R3dCr0ss View Post
    You messed up your whole server with that action. You can't fix this anymore.
    You must start your server from sctatch. If no working backup is available.
    For the future:
    You must delete the whole client to get rid of the login. Currently there is no way to just delete the account for users (but this has been requested and added into a ticket already).
    I did move the thread to the right topic after reason for the problem was found
    Edit///
    Do not do anything else as you were told in this post.
    Threads and posts with unsupported soloutions will be deleted on this forum.
    We do not give any support for manipulation in the databse.
  1. I delete serveradmin from Admin Server Query group
    By p1kox in forum Permission System
    Last Post: January 16th, 2013, 08:10 AM
