Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    October 2015
    15
    Does anyone have any ideas for the bot? Submit them here
  2. #17
    June 2016
    Was playing to have a look. How to uninstall?
    I have (or so I thought) removed the directory oct/bot but every time people log in they still get a welcome message this is the only service running how to disable it.
  3. #18
    June 2016
    Install
    Where schould be placed the run.sh script?
    Every time i became eroor that the ./run.sh could not be found
    Tnx
  4. #19
    June 2016
    Stopping/Restarting the bot
    In the instructions, there is nothing about how to stop the bot which is frustrating when you're testing it out and changing settings. I had to manually kill the process. It would be helpful to include something to reload config.ini or restart the bot and the option to fully shut it down.
  5. #20
    June 2016
    Killing the process
    Quote Originally Posted by kanalumaddela View Post
    Could you please talk me through how to kill the process.
    Ta.
  6. #21
    June 2016
    Quote Originally Posted by nyxviliana View Post
    Ta.
    Replace <user> with the name of user the bot is running under
    ps -u <user>
    find the PID which is the number located on the left side column. Then type
    kill <PID>
    where PID represents the number of the process. If it doesn't work with that try doing it with sudo.
    I finally was able to configure this and access it the web interface which is pretty basic imo. It would be nice to be able to configure settings like the afk mover, support notifier, and banner through it.
  7. #22
    June 2016
    ta
    Thanks that worked.
    In my defence to the next statment its a private VPS for the point of a private TS address no sensitive data so not worried about security.
    I ran it under the root user so I had to take an educated guess as to what PID it was out of the list.
    Thanks again
  8. #23
    June 2016
    Exclamation Java Error
    Currently this error shows and spams console when I run the bot, the bot is connected to the server, but lags 20-40 secs on simple commands like !help, !website, and !login
    java.lang.NullPointerException
            at net.scrumplex.sprummlbot.GoicqOVehRY68RCP7lXb.qgZSyjGOVNPGbBZt5NUv.qgZSyjGOVNPGbBZt5NUv(Unknown Source)
            at net.scrumplex.sprummlbot.U7BGYfJ3PqmaifNou2pK.handleSuccess(Unknown Source)
            at com.github.theholywaffle.teamspeak3.api.CommandFuture.set(CommandFuture.java:451)
            at com.github.theholywaffle.teamspeak3.TS3ApiAsync$20.handle(TS3ApiAsync.java:1859)
            at com.github.theholywaffle.teamspeak3.SocketReader$2.run(SocketReader.java:154)
            at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
            at java.util.concurrent.FutureTask.run(FutureTask.java:262)
            at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
            at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
            at java.lang.Thread.run(Thread.java:745)
  9. #24
    February 2016
    Question Questions and ideas
    Question
    1) Is it possible to translate the bot into another language? including web panel. Tried to just simply edit the English to Danish in the files, but it didn't seem to change anything.
    2) I think there might be something wrong with your website. I tried to sign up for an account, but never received E-mail containing the password.
    Feature Requests / Ideas
    Sorry if i overlooked something, and it turns out that some of these are already possible.
    1) Different Server Groups, I.e "Moderator" would only have access to ban people via the web panel for a maximum of how many hours you would write into the CFG. + "Moderators would also only have access to unban people they've banned.
    2) option to change it so you can write "!login" in every channel on the teamspeak to receive the login information.
    Problems
    1) Logins provided by the bot by using !login on teamspeak is not always working.
  10. #25
    August 2013
    542
  1. Lightweight teamspeak
    By Fearvich in forum Suggestions and Feedback
    Last Post: October 1st, 2014, 12:20 PM
