Results 1 to 6 of 6
    February 2016
    Canada
    9
    Connection issues since upgrading to 3.0.12.2
    We are an ATHP and have upgraded all of our servers from 3.0.11.x to 3.0.12.2. Having done the upgrade last weekend, we have since been advised of connection issues.
    The issue that occurs is that, after some time (the time period varies greatly), users are suddenly unable to connect to the Teamspeak server, receiving a "Failed to connect to server" error in the Teamspeak client when trying to connect. In order to resolve the issue, the server owner needs to do a 'restart' of the Teamspeak server (through our control panel, TCAdmin), after which people are immediately able to connect again.
    The main server log, as well as the actual virtual server log, do not show any errors that indicate any problems. The only entry in the virtual server log is the normal entry shown after the server is restarted.
    What could cause this issue? This did not occur on 3.0.11.x, and rebooting the physical server did not help resolve this.
    18,513
    Which OS do you use?
    Are you firewall rules updated for the new binary too?
    Do user also have problems, when they use the server IP + Port directly then?
    February 2016
    Canada
    9
    OS: CentOS 6.6 x64
    I renamed the Teamspeak folder to the old one, so the binary shouldn't have changed -- so firewall rules shouldn't need to be modified
    Yes, they have problems not just with hostname : port but with ip : port also
    Where can I start looking?
    February 2016
    Finland
    I'm having exact same problems...
    Debian 6.0.10 LTS
    Linux 2.6.32-5-amd64 #1 SMP Sat Sep 19 22:03:27 UTC 2015 x86_64 GNU/Linux
    |TeamSpeak 3 Server 3.0.12.2 (2016-02-15 14:51:38)
    |SystemInformation: Linux 2.6.32-5-amd64 #1 SMP Sat Sep 19 22:03:27 UTC 2015 x86_64 Binary: 64bit
    |max virtualservers: 10
    |max slots : 512
    I'm having no errors what so ever but only some ppl can connect to server at this monent.
    I made a rollback to older version so now I need to see if it works better or not...
    Version: 3.0.11.4 [Build: 18.08.2015 16:30:34]
    July 2006
    1,600
    I'd like to refer to a similar problem I've had before: http://forum.teamspeak.com/threads/1...ew-connections
    I did not encounter this issues after the software upgrade (probably because there has not been ddos to my server), however maybe this hasn't been fixed by the recent server software updates.
    February 2016
    Canada
    9
    Quote Originally Posted by maxi1990 View Post
    Thank you for providing this info!
    @ Teamspeak: Can you please respond and advise if this is possibly the issue, and how to resolve in 3.0.12.2?
  1. Connection Issues
    By weredperson in forum Server Support
    Last Post: July 7th, 2013, 10:09 PM
