Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    18,151
    Do you have a screenshot and is this the 64 bit client?
    In case it is the 64 bit client on Vista -> You must use the 32 bit client till client 3.0.20 is released. This is a known visual c bug and wil be fixed with an updated version which will be included in client 3.0.20.
    3.0.19 is a preporation for this update.
  2. #17
    April 2016
    thanks for the answer yes i am using 32 bit this is the warning Name:  ????? ?????.jpg
    A referral was returned from the server. is the translation
  3. #18
    18,151
    "A referral was returned from the server"
    This happens, when the software isn't trusted or blocked from Windows
    tnx for translation
    Try this
    Open File properties of the setup file (if that's what you are referring to) or the actual client binary. Then click the digital signatures tab, double click the only entry in the list, click view certificate, certification path.
    All those Certificates should be valid and trusted by your operating system by default (unless you manually removed or blacklisted certain certificate authorities).
    As said for the setup installer package you can compare the hash directly on the download page where the hash is stated, if you need the actual client executable one I will see if I still have some old installation around.
    //Edit
    Can not reproduce this on Vista with Stable installer and updater
  4. #19
    April 2016
    tnx for translation
    Try this
    //Edit
    i checked everything mate they are all certificates valid and still have the same problep.i would appreciate it if you could send an older version
    i do not know what i did but i manage to make it work :P
  5. #20
    August 2015
    I tried : /usr/syno/etc/packages/ts3server
    And /var/packages/ts3server
    And /volume1/@appstore/ts3server.
    Did i do wrong?
  6. #21
    April 2016
    9
    French translation
    When I first saw: "+ Added French [...] translation", I thought "Yes, nice!" but after 10 seconds with this new version, I had to check if it was the 1st of april... (bloody april fools' day!) I just can't imagine that a french speaking guy helped you on that... It was already hard to explain the permission system to a noob but now with that translation... It's impossible!
    An example of how bad the translation is is the fact that "Speex Wideband" becomes "Speex bande large": to me, it just sounds like the text on a condom pack. (and that's just an example among many)
    By the way, you can change the title of the thread, it's not a beta anymore.
  7. #22
    April 2016
    Quote Originally Posted by loyros View Post
    same problem here, got Vista Home Basic, updated client (the 32bit one) to 3.0.19, and when I try to open it I got "A referral was returned from the server" error
  8. #23
    November 2011
    Belarus
    141
    Before you guys release new version on stable channel, please, update built-in Overwolf installer (its crashes on my win10x64 every time i click on user icon, and, yes, i'm on latest beta)
  9. #24
    18,151
    Does not happen for me in 32/64 bit client. The installer works fine.
    The first double click on that icon asks me to install .net Framework 3.5 (must be installed to start the overwolf installer).
    And after i did install ".Net Framwork 3.5" it starts the included installer.
  1. [Beta Channel] TeamSpeak 3 Client 3.0.17
    By PeterS in forum Archive
    Last Post: August 10th, 2015, 08:35 AM
  2. [Beta Channel] TeamSpeak Client 3.0.14
    Last Post: March 13th, 2014, 07:34 AM
  3. [Beta Channel] TeamSpeak 3 Client 3.0.12
    By dante696 in forum Archive
    Last Post: September 8th, 2013, 10:05 PM
  4. [Beta Channel] TeamSpeak 3 Client 3.0.10
    By Chris in forum Archive
    Last Post: March 4th, 2013, 09:22 AM
  5. Replies: 47
    Last Post: April 23rd, 2012, 08:27 AM
