Results 1 to 8 of 8
    March 2016
    TS3 playback issue
    Hi..
    I am having an issue with TS3 which.. is.. a bit complicated so i will explain my setup first
    To start with i will say already that i have my Audio drivers updated to the newest version already
    also i have the latest TS3 installed 3.0.18.2 QT 5.5.0
    Alright.. im running a MSI GT72 2QE laptop over my stereo via SPDIF optical cable (stereo is too old to have HDMI)
    This setup gives excellent sound and the ability to run digital sound directly into the amp (DTS & Dolby Digital)
    When running normally windows sends the output via SPDIF as PCM
    however when running DTS or Dolby Digital the SPDIF format can only transmit that single signal compressed which means any PCM sounds are disabled (ie. nothing else but the movie can transmit sound) which is the way it is supposed to be when limited to optical Toslink
    When i then close the movie windows automaticly switches back from the digital format to PCM and voila.. firefox.. winamp.. windows.. everything is able to transmit sound again... EXCEPT.. TS3
    for some reason TS3 has some sort of problem when going back to PCM and wont play audio.. i have found a simple though annoying solution which is to change "playback mode" under playback from "Direct Sound" to "Windows Audio Session" then apply.. then change back from "Windows Audio Session" to "Direct Sound" then TS3 has its sound back... but still its a bit annoying having to do this every time i have opened a movie (since i upscale all movies audio to 5.1 DTS)
    So if either the developers could look into what is causing the inability to resume proper playback along with the rest of windows when going back to PCM or any helpfull tweaks that could cause it to automaticly work properly again
    In advance thnx for any assistance
    18,396
    One difference to the other mentioned software is -> We search and use default communication device, when "Default" is selected as your device in TeamSpeak.
    Maybe it helps, when you select the soundcard / device directly instead of using "Default".
    What does your client log say, when you switch back to PCM?
    March 2016
    Have tried both letting it stay at default and forcing the playback device to use "Realtek Digital Output (Realtek High Definition Audio)" which is the SPDIF.. makes no difference.. only changing the playback mode back and forth
    and the log says
    02/03/2016 14:48:38 Direct Sound Error ERROR (-203 -2005401450): Buffer memory has been lost, and must be restored
    18,396
    Does that also happen, when you use Windows Audio Session in your profile?
    ---> I forgot to ask that before.
    March 2016
    Yes.. it doesnt matter if i use audio session or direct sound before i play DTS i still have to switch back and forth to get the sound working again
    October 2012
    553
    While not automatically, in the meantime until this gets solved I think you should be able to ease the pain by using hotkeys (advanced) to toggle between two playback audio profiles back and forth between DirectSound and Wasapi which should effectively result in the same reset you're currently doing (assuming you didn't do that already).
    March 2016
    Nope didnt consider you could actually create a second profile to hotkey over to.. great idea will definately make it less annoying..
    Ofcourse im hoping the devs might find out why TS3 doesnt resume playback properly by itself when all other programs and windows do so and fix it in an eventual patch..
    but till then this is a great solution.. thank you very much
    18,396
    I will forward this to the developers and put this thread under evaluation.
    We will report back, when we can tell you more.
  1. No playback sound
    By rmcconn in forum Windows
    Last Post: June 9th, 2015, 10:20 AM
  2. Replies: 0
    Last Post: March 1st, 2014, 03:43 AM
  3. playback
    By Naiteki in forum Windows
    Last Post: April 29th, 2010, 01:14 PM
