Results 1 to 3 of 3
    March 2016
    startConnection 519 could not validate client identity
    Some users from my Game get this error from the Ts3 SDK client "Could not validate client identity"
    Its possible to disable the identity check on the Server?
    6,079
    No.
    How do you create the identity used in the connect call?
    There is a function createIdentity that creates one which you can use, this should work without problems.
    If you do get this error when using a cached identity from a file, you may want to consider the cached one invalid and create a new one, then connect with that.
    March 2016
    Thx Solved
  1. Replies: 1
    Last Post: September 16th, 2013, 10:16 AM
  2. Replies: 7
    Last Post: May 26th, 2013, 07:35 PM
  3. Replies: 16
    Last Post: September 19th, 2011, 04:08 PM
  4. Replies: 10
    Last Post: August 14th, 2011, 11:48 AM
  5. Could not validate client identity
    By BABOOB in forum iOS
