Results 16 to 30 of 32
  1. #16
    August 2013
    530
    I'd like to mention a solution which was posted to our Facebook wall by Tom 'FANnatiker'.
    Quote Originally Posted by Tom Nicklisch
    for all people who have problems with the 3.0.19 on OSX 10.7.5
    i use PlayOnMac (its free) and there you can install teamspeak for windows
    winebottler is nice but there crushes the ts
    WinOnX and Crossover don't know
    or you use a Virtualmachine on VMware Fusion or Pallels - i used xubuntu and it works fine
    Thanks for sharing your Suggestion, Tom.
  2. #17
    May 2011
    Exclamation
    My client crash immediatley
    server runing on Version:3.0.12.3 auf Linux
    crash report
    http://pastebin.com/t3PpYXMD
  3. #18
    17,947
    Please update to OS X 10.8 or newer or try the soloution from post #16
    That's the only way to solve this.
  4. #19
    May 2016
    TeamSpeak crashes when I open it.
    So i downloaded TS on my Mac 11 inch which is running OSX 10.7 and every time I try to open TeamSpeak it crashes after about 1 second. I have re-downloaded it a countless amount of times. I'd really appreciate some help but I'm not really sure how to upload a my Error Report or past it in.
  5. #20
    17,947
    Your OS is outdated and the client needs OSX 10.8
  6. #21
    July 2016
    Sad to want to force people to change their hardware.
    Your outdated operation system does not support Secure Transport which was added in OS x 10.8.
    We know that it does crash and we know why, but we can not fix this!
    You must update your computer to OS x 10.8 or newer.
    This is ridiculous!
    It is public and notorious that it has MACBOOK 2007/2008 not able to upgrade to version 10.7 to 10.8 because Apple does not give the possibility of updating.
    I see that many then migrate to another VOIP system for their devices.
    Sad and unnecessary.
  7. #22
    17,947
    Quote Originally Posted by luizhvaisconcelos View Post
    This is ridiculous!
    It isn't because we needed to add features into the client which are only availbale on newer OS X version to make sure the client still is running on these systems.
    This makes it incomaptible with older version, becasue they do not have that feature.
    Apple does force us to add things into the client to support the latest version.
    I'm pretty sure we also need to raise the version number again, when macOS became public.
  8. #23
    July 2016
    Unhappy
    Thank you for your explanation, and not only does not work as in previous topics.
    I see that slutty comes from Apple, lol ...
    Well, then I and a large portion of the old MacBook users we will be waiting for a version that can be copativel with our devices and so let's go back to use the app again.
    Grateful!
  9. #24
    17,947
    I did explain in post #11 why the client needs 10.8.
    This is such an feature that is missing in 10.8 but was needed in client to work.
  10. #25
    September 2016
    i really need teamspeak and it doesnt even work...
    teamspeak, this problem has been going for way too long and you still dont even fix it... im using Mac OS X Version 10.7.5
    ive read some forums saying that teamspeak only works for above version 10.5 ... i think. so idk if i have a diffrent problem, all i know is that teamspeak doesnt care about mac users...
    Last edited by dante696; September 6th, 2016 at 09:11 AM. Reason: merged, your statement isn't true. explained 2 posts above
  11. #26
    September 2016
    An application should handle incompatibilities gracefully
    I understand that the developers of Teamspeak feel that Apple leaves them no choice in this, however I don't think that the developer is doing their part by allowing the application to communicate this issue by crashing ungracefully. Have the app detect this situation and offer a dialogue with a link to a knowledge-base article. Otherwise it appears that the the developer is just coming up with excuses.
  12. #27
    17,947
    Quote Originally Posted by trufyre View Post
    You are right.
    I write a ticket for the developers and we will see if we can prevent something like that in the future.
    //Update
    The next installer 3.1 will reject to install on OS X older than 10.6 to avoid crashes.
  13. #28
    May 2011
    Crash Report
    Your OS Hello,
    i have a problem my TS client Crash instant on my Macbook Pro 4
    Please Help Me
    http://pastebin.com/28fbeXCS
    Last edited by dante696; October 3rd, 2016 at 06:13 PM. Reason: your OS version iss not supported
  14. #29
    August 2015
    Trouble using Teamspeack with macBook 10.5.8
    I used teamspeak with my old macbook, but recently I got an error message when I try to connect. Looks like mac os 10.5.8 is left behind
    Is there any way to continue to use ts anyway? A patch? Something else?
    Thanks a lot for your help
  15. #30
    September 2017
    10.8.5 broken too
    Suggesting an upgrade to 10.8 isn't going to fix anything for many of your users. I've got 10.8.5 and I'm having the exact same crash on startup issue. Since 10.8.5 is the natural update for 10.8, anyone who tries to upgrade will be met with the same problem. Are you guys going to release a patch for 10.8.5 or hell even a separate version of the older client that we can still run?
  1. Server asked for newer client version
    By Myszax in forum Client Support
    Last Post: January 9th, 2017, 03:30 PM
  2. [Not Supported] Client 3.0.17 (and newer) on OSX 10.5 /10.6 / 10.7
    By furicle in forum macOS
    Last Post: April 12th, 2016, 07:30 AM
  3. Where to send translations for 3.0.16 and newer?
    By Hawk19 in forum General Questions
    Last Post: October 20th, 2015, 08:41 PM
  4. [Rejected] newer MySQL support
    By sdousley in forum Server Support
    Last Post: April 17th, 2015, 07:44 AM
  5. cant download newer versions
    By Hyspin in forum Off Topic
    Last Post: March 24th, 2014, 10:32 AM
