Results 1 to 5 of 5
    April 2016
    Russia
    14
    TeamSpeak error: failed connection initialization
    I using TeamSpeak as module in UE4.
    And also I used server from voice-server.ru
    So I call the
    ts_lib->TeamSpeak_startConnection(ConnectionHandlerID, ID, "ts1.voice-server.ru", 10024, player_name, DefaultChannelArray, "", "secret", error);
    And after that OnConnectStatusChangeEvent fired with errorNumber = 1797 (failed connection initialization)
    Server with port is registered. What I doing wrong? Need a password? Default channel password?
    17,922
    Your description sounds like you are using a the client from SDK and just a normal server.
    You must connect to a SDK server, when you use an SDK client.
    April 2016
    Russia
    14
    What I'm doing wrong? I use the server with 50 slots, and I want connect to this server with my SDK client. SDK client and this server incompatible? What now?
    6,076
    SDK Client is only compatible with the SDK server.
    You cannot connect to a regular server using an SDK client, nor can the regular client connect to an SDK Server.
    When using an SDK client you also need to create and host an SDK server.
    It's up to you whether you want to create, host and use a standalone server or whether you integrate the server part in your (client facing) application and dynamically choose one client to also be the voice server and have the other clients connect to that client hosted server.
    May 2016
    Why?
    Why the hell is that? I just spend a huge amount of time learning golang and wrapping your sdk and now I can't use my own code thanks to teamspeak restricting everything? Why don't you just made sdk clients optional by configuration? Can this be done in future releases?
  1. Initialization Failed
    By Pavel in forum Bug Reports [EN/DE]
    Last Post: March 6th, 2012, 02:03 AM
