Results 1 to 2 of 2
    May 2016
    Problems combining teamspeak server with vestaCP
    I'm pretty new to linux, I used my ubuntu server as a teamspeak server but now I want to combine it with VestaCP.
    The problem is as soon that I install VestaCP, I can't connect to my Teamspeak server anymore.
    Can someone explain me why this happens and if it's possible to fix?
    Regards,
    Raudshow
    June 2015
    VestaCP should always be setup on a new install of a system firstly, but I've never experienced too many issues ;P
    Have you opened the ports on your control panel's firewall? That should be the only issue stopping Teamspeak from running in conjunction with Vesta.
    Teamspeaks default ports are as seen below
    Default voice port (UDP in): 9987
    Default filetransfer port (TCP in): 30033
    Default serverquery port (TCP in): 10011
    Default tsdns port (TCP in): 41144
    Default weblist port (UDP out): 2011-2110 (first available port in given range)
    source
    edit:
    if you want to install vesta without IPTables rerun the installation command with bash vst-install.sh --iptables no and then remove it with your systems uninstall command
  1. combining privilege keys
    By ThatBoyBlue_7L in forum Server Support
    Last Post: May 5th, 2016, 08:25 AM
  2. Replies: 3
    Last Post: August 2nd, 2010, 08:47 AM
