Page 7 of 14 FirstFirst ... 56789 ... LastLast
Results 91 to 105 of 198
  1. #91
    September 2017
    Erro no teamspeak
    Estou com um erro que meu teamspeak fica crahando toda hora alguem me ajuda
  2. #92
    September 2017
    TeamSpeak crasha na inicializaçao
    Meu teamspeak quando tento abri-lo ele crash como eu possa resolver este erro? ultimo crashdumps esta anexado
    Edit by mod
    ClientUI | |Unable to create an Open GL context.
    Please read:
    http://forum.teamspeak.com/threads/1...389#post448389
    Attached Files Attached Files
  3. #93
    September 2017
    Não Mostra
    Porque o meu Team Speak 3 quando eu vou abrir ele não aparece na tela do meu computador mais ele esta aberto?
  4. #94
    October 2017
    0
    Problema para ver los iconos del ts3
    Me pueden ayudar con ese problema cada ves que entro al sv de mi clan me sale que no puedo ver los iconos, alguna manera de arreglar este problema?
    http://prntscr.com/guj76p
  5. #95
    October 2017
    0
    не могу зайти на сервер
    Не удалось разрешить имя хоста «deadly.ts3serv.net»
  6. #96
    October 2017
    0
    Falha ao conectar ao servidor
    Alguém pode me ajudar ?
  7. #97
    October 2017
    Ts server + vpn
    Bonjour,
    J'ai TS SERVER chez moi et j'ai récemment installé un VPN (HMA).
    Depuis, mes amis n'arrivent pas à se connecter à mon server TS.
    Quand je suis sur le même réseau, cela fonctionne (autre ordinateur à coté de moi), mais depuis une connexion différente, cela ne marche pas.
    J'ai essayé de me connecter via l'adresse IP source, ou celle du VPN.
    Quelqu'un aurait-il une solution ?
    Merci d'avance.
    Cordialement.
    Vava
    I have TS SERVER at home and I recently installed a VPN (HMA).
    Since then, my friends can't connect to my TS server.
    When I'm on the same network, it works (another computer next to me), but from a different connection, it doesn't work.
    I tried to connect via the source IP address, or that of the VPN.
    Would anyone have a solution?
    Thank you in advance.
    Cordially.
    Vava
  8. #98
    October 2017
    Erro de não detectar microfone
    Estou com um problema , estou usando microfone e não detecta : http://prntscr.com/h29wom clico no + verde e escolho o nome mas mesmo assim não cria o perfil!! por favor preciso de ajuda : http://prntscr.com/h29xf5 mas estou com micro ja testei gravando e detecta em todos !! por favor me ajudem.
  9. #99
    November 2017
    0
    Integração Vbilletin e TS3
    Estou querendo fazer uma integração so meu TS3 junto com o meu forum: allygreece.com.br
    Gostaria de manter o controle de acesso dos membros conforme o meu forum, alguem poderia me ajudar?
    Desde já agradeço!
  10. #100
    November 2017
    0
    Erro ao abrir team speak 3 [appcrash]
    Ajuda URGENTE
    Estou com dois problemas ao abrir o team speak 3 (print do erro a baixo)
    ja tentei de tudo formatei 8 vezes o meu pc , mesmo assim o erro insisti no win7 em todas as versões ! esta impossível de resolver este problema .
    Obrigado dez de já , aguardo resposta ! Click image for larger version.
Name:	Sem título.jpg
ID:	16135Click image for larger version.
  11. #101
    November 2017
    al ti ga ucera u republiku sumsku :*
  12. #102
    November 2017
    0
    Question importante!!!
    Bonsoir, j'aimerais savoir si je pourrais limiter un certain nombre d'utilisateur à un grade, en gros j'ai créer des groupes pour un certain nombre de personne mais le problème c'est que les utilisateurs se mettent à 5 ou 6 dessus alors que j'ai demander qu'il n'y ai que 3 personnes maximum!
    Merci de votre aide.
  13. #103
    November 2017
    0
    Permission
    J'aimerais savoir is c'est possible et comment faire pour limiter un grade à un certain nombre de personne???
  14. #104
    November 2017
    0
    Problemas ao entrar em alguma sala no TeamSpeak
Name:	Sem título.png
    não consigo ver as pessoas que estão conectada no TeamSpeak, pq isso?
  15. #105
    November 2017
    0
    [PROBLEMA] Crash/Parou de Funcionar
    Bom dia, meu teamspeak parou de funcionar, não sei o que aconteceu, comprei este PC e não quer funcionar o TS Confg:
    Intel atom 32bits
    baixei o teamspeak conforme a minha configuração, tentei de tudo mais não funcionou até mesmo compatibilidades, não sei mais o que fazer obs: estou usando windows8 pro 32 bits, olhem as print
    https://imgur.com/a/XNth8
  1. Replies: 2
    Last Post: July 29th, 2015, 09:35 AM
  2. Forum Home button | Forum Ease of Use
    By BHKai in forum Suggestions and Feedback
    Last Post: August 6th, 2011, 05:05 AM
  3. Support for other languages
    By Suffer in forum Suggestions and Feedback
    Last Post: January 7th, 2010, 12:29 AM
  4. [Resolved] TS3 will support SWITCH LANGUAGES?
    By SniperLiao in forum General Questions
    Last Post: November 26th, 2009, 01:09 PM
