Results 1 to 5 of 5
    May 2016
    Question TeamSpeak 3 stops sending my voice after a few minutes
    I just bought a new microphone (a Samson Meteor to be exact) and when I'm on any TeamSpeak Server the mic works as it should but after a few minutes, TS just stops sending my voice! (The mic continues to work on every other program!)
    The only way to temporarly fix this is to reconnect to the server but the same thing happens again!
    There is no indication on my or the other side that my mic is muted - I only notice it when my mates say they can't hear me anymore!
    I'm on Windows 7 with TS version 3.0.19.1
    Any suggestions?
    Thanks, TheJanzap
    18,151
    Please show us a client log (afteryour problem appeared again).
    Update your drivers and try another USB port in case you have an USB Soundcard or headset.
    June 2016
    Hey Dante,
    i have the exact same problem described by the topic creater and im about to throw my hole computer out of the window.
    To give you a little bit more background info i'd like to list what i tried and give you a more 'in depth' description of the problem itself. (when/where it appears).
    First things first:
    On the 4th of June i had problems with my PC running slowly and got stuck several times. There was no problems with either TS, my mic or my headset.
    On the 5th of June i finally managed to 'hard reset' my pc (keeping personal data files).
    <my op>
    System Information
    Time of this report: 6/9/2016, 18:42:55
    Operating System: Windows 10 Pro 64-bit (10.0, Build 10586) (10586.th2_release.151029-1700)
    Language: German (Regional Setting: German)
    System Manufacturer: ASUS
    System Model: All Series
    BIOS: BIOS Date: 11/27/14 10:47:44 Ver: 21.06
    Processor: Intel(R) Core(TM) i5-4670 CPU @ 3.40GHz (4 CPUs), ~3.4GHz
    Memory: 8192MB RAM
    Available OS Memory: 8124MB RAM
    Page File: 2661MB used, 7383MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: 12
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    Miracast: Not Available
    Microsoft Graphics Hybrid: Not Supported
    DxDiag Version: 10.00.10586.0000 64bit Unicode
    Card name: NVIDIA GeForce GTX 660
    Manufacturer: NVIDIA
    Chip type: GeForce GTX 660
    DAC type: Integrated RAMDAC
    Device Type: Full Device
    Device Key: Enum\PCI\VEN_10DE&DEV_11C0&SUBSYS_36251458&REV_A1
    Display Memory: 6051 MB
    Dedicated Memory: 1988 MB
    Shared Memory: 4062 MB
    Current Mode: 1920 x 1080 (32 bit) (59Hz)
    log file of my client will be posted as i get the bug again.
    So i kept downloading and installing the most of my previous programms. (including Teamspeak)
    I set everything up in the client, Direct Sound, <Logitech Gaming Headset>, made sure that voice activation works fine and got ready for some overwatch with my friend. (Yes, after my hard reset i changed the USB-Port of my Logitech G430 from a regular 2.0 port to a 3.0 port since i unplugged one of my mices)
    Windows Settings for my Headset:
    -Exclusive Mode for Programms turned off (so nothing can change these settings until i do it)
    -Ohter settings are set to default.
    So after starting 'Overwatch' we played for a couple of minutes and boom, problem above appaered. I nearly freaked out because if you hard reset your pc, you assume that everything works like back then. False.
    So i played a bit around in the settings of the ts client, switched to Windows Audio Session to automatic and back to direct sound, and everything worked again.... for the next 15 minutes. After that, same problem.
    I closed the client, somehow it froze while try to shutting it down (happened 3x to me allready)
    Restarted it, and it worked again for the next 15 minutes.
    As in the next 15 minutes while it worked, i played a bit around in the windows settings of my Gaming Headset/Mic and somehow the 'bug' or w/e you wanna call it, appeared right away. Not after the 15 minutes or so.
    What i've tried so far:
    - restarted my pc
    - reinstalled teamspeak (i also installed a 32bit version to check if it is a 64bit problem, currently running the 32bit version)
    - checked my mic and my headphones for driver updates
    - checked my mic in windows as the bug appeared (and it is activated, and works perfectly, but not in the ts client)
    - Exclusive Mode for Programms turned off so nothing can change these settings until i do it
    - checked if there is any update on my logitech gaming headset itself (firmware etc)
    What i didnt try out so far:
    - update my usb port drivers
    - changed to another usb port (as you suggested).
    I'll keep you guys updated.
    18,151
    You gave a lo of details but on important thing is missing.
    The Client log ??? This was sentence one in my reply.
    June 2016
    The Client log ???
    as i said, log will be posted as soon as i get the bug again.
    I guess it's fixed.
    My USB ports drivers were up to date allready, so what really got it fixed was the driver update of my headset in the 'device management' (right click, update driver). Even though the logitech gaming software said that the headset was up to date anyways. Weird world.
    + i changed my usb port back to a normal 2.0 one.
    I'm testing it now for about 1 and half hour and the bug did not appear again.
  1. [Resolved] Sound Input stops after about 10 minutes
    By bzf-online in forum Windows
    Last Post: November 11th, 2015, 11:09 AM
  2. TS3-Server stops after about 24 minutes using MariaDB
    By whfor in forum Linux / FreeBSD
    Last Post: April 15th, 2015, 03:53 PM
  3. server stops after a few minutes
    By lawndart in forum Linux / FreeBSD
    Last Post: April 15th, 2012, 03:43 PM
