Page 12 of 12 FirstFirst ... 2101112
Results 166 to 178 of 178
  1. #166
    September 2019
    Add loop checkbox
    Is it possible to add a loop checkbox, in order to play a sound infintly ? It could be very useful to have a ambiant sound for a long time.
    Thank you
  2. #167
    October 2019
    Plugin rp_soundobard
    PLugin failed to load : Api version is not compatible : 22 ( minimum:23, current 23 )
    Help... thanks ..
  3. #168
    October 2019
    I need help with RP Soundboard
    Hello together
    I am Swiss ( So I hope you understand my English XD)
    I have a problem with the RP Soundboard. I really spent 3-4 hours in songs and downloading sounds, so it's really annoying. Every time I play music/sound and then click once with the left mouse button the sound goes away and I have to choose it again. e.g. if I change the volume and press the left mouse button I have to choose the sound again. Do you know how I can fix my problem?
    Best regards
    joel
  4. #169
    January 2017
    Switzerland
    461
    Quote Originally Posted by xJoeLx View Post
    Hello together
    Best regards
    joel
    I think your song (file) was not found anymore.
    You should get them all in a directory where they can't get lost anymore.
    don't locate them somewhere at "temp" or other unsafe directories.
    Choose the file from the located directory and don't move or delete them at their current directories.
    Quote Originally Posted by gianni567 View Post
    Help... thanks ..
    Update your TeamSpeak 3 Client to the latest stable version.
  5. #170
    September 2019
    Add loop checkbox
    Do you have a solution to play a sound infintly ? It could be very useful to have a ambiant sound for a long time.
    Thank you
  6. #171
    October 2019
    could you provide the linux version of your plugin for teamspeak 3.3 please ?
    Thank you for your job,
    Amaran.
  7. #172
    October 2019
    Hey, great soundboard! Unfortunately the volume adjustemnt is always skipping to maximum volume after i left click. this happened today the first time and never before.
  8. #173
    October 2019
    hey,
    my problem is that i can not click configurations
    its hiding in my start menu bar
    the soundboard is not fitting my fullhd screen
    please help
  9. #174
    November 2019
    Failed to install Add-On
    I keep getting this error *Failed to install Add-on,Do youw ant to retry as Administrator*
    I click on yes and still get it
    https://imgur.com/a/RiawVDb (Error Screenshot)
    SOOOOOS
  10. #175
    November 2019
    Quote Originally Posted by MCG View Post
    I have the same problem with the newest release of TS3 so that doesn't fix it. It still says Api version is not compatible : 22 ( minimum:23, current 23 )
  11. #176
    November 2019
    F13-f24
    can you somehow bind F13 to F24 as hotkeys?
  12. #177
    January 2020
    I just wanted to say.. i love your soundboard, easy to use.. but threi s just something id like to see added.. that you can basicly skip pieces in the song.. like you can do in mediaplayers. Skip pieces in the audio file
  13. #178
    September 2015
    28
    Hey,
    i have a problem with the soundboard. The sounds are very very quiet for me but loud for others and that is really boring.
There are currently 3 users browsing this thread. (0 members and 3 guests)
  1. Soundboard for Mac ?
    By Vicious919 in forum Client Plugins / Lua Scripts
    Last Post: May 24th, 2017, 07:24 PM
  2. Android App Soundboard
    By ocean in forum Off Topic
    Last Post: August 13th, 2016, 11:54 PM
  3. Microphone/Soundboard Help
    By ADudeWithAHat in forum General Questions
    Last Post: December 31st, 2013, 12:00 AM
  4. [RELEASE]TS3 Soundboard GUI
    By Nuwen in forum Client Plugins / Lua Scripts
    Last Post: September 2nd, 2013, 06:41 PM
  5. Soundboard GUI need help
    By Nighthawk354 in forum Windows
    Last Post: May 30th, 2012, 04:46 AM
