Results 1 to 6 of 6
    June 2016
    Port 9987 Will not open, No matter what i try
    Hey guys i know a lot of people have asked/ said this a lot but I've followed every single one of the threads and nothing is working.
    So basically I'm trying to start up a dedicated server for me and my mates as a gaming server (5-10 people) and everything works fine server wide.
    Now I'm not exactly an expert at port forwarding but i have knowledge of how it works and how to use it.
    When i load up the server i am able to join it with my local ip but anyone else cant join/ i cant with my external ip.
    Ive set up 3 port forwards:
    1. TCP on 30033
    2. TCP on 10011
    3. UDP/TCP on 9987
    Port Forwards:
    http://puu.sh/pzhIF.png
    When i check the ports using yougetsignal and Canyouseeme the first and second one come up as open but the 9987 port doesn't open.
    http://puu.sh/pzhP5.png
    http://puu.sh/pzhPU.png
    http://puu.sh/pzhQU.png
    I've tried disabling my firewall and AVG, Ive tried DMZ'ing my computer, I've tried everything i can think of but no matter what this port will not open. I have a static internal ip and the external isn't too much of an issue as it just got renewed and it changes every month or so and i can keep up with that.
    I've tried changing it from both to just one, changing it to TCP, then UDP nothing.
    Router: HUAWEI HG532d
    OS: Windows 10
    If you need any other info just ask. Thanks in advanced.
    I'm currently stuck using EVOLVE (Hamatchi replacement) and it's really annoying.
    6,080
    UDP is connectionless, as such port testing tools will most likely show it as unknown / filtered / closed.
    18,302
    1. Please only port forward UDP for the voice server and not TCP/UDP mode.
    Some devices do have problems with that mixed mode.
    2. Make sure your computer has the IP 192.168.1.100. This can change when you use DHCP in your router.
    3. Are you sure that your server IP bindings for voice are 0.0.0.0 or 192.168.1.100. You can see this in server log _1
    4. The mentoined websites are not able to check UDP ports. You better use a real person for testing.
    June 2016
    So when i want people to join what do i get them to put in?
    *External ip*:9987?
    18,302
    Yes this would work.
    They only need your external IP, when the server runs on port 9987.
    The client always does connect on port 9987, when no other port was entered.
    June 2016
    Thank you everyone for your help, After restarting the router one more time and getting a person to try it it worked!
    image with private details removed
  1. Port 9987 won't open
    By AM-99 in forum Server Support
    Last Post: November 20th, 2016, 08:16 PM
  2. Port 9987 wont open no matter what i do!!!
    By LiightsHD in forum Server Support
    Last Post: August 20th, 2015, 05:36 PM
  3. Port 9987 Problems
    By Russ1544 in forum Windows
    Last Post: July 26th, 2012, 06:12 AM
  4. Replies: 1
    Last Post: October 24th, 2011, 08:55 AM
