Results 31 to 45 of 51
  1. #31
    August 2013
    540
    Teamspeak dropped XP support since 3.1.8
  2. #32
    September 2005
    Germany / Dortmund
    1,376
    Which version do you use?
    If you use the "myTeamSpeak-version": I seriously don't know anymore, how I built this, so there might be some issues on my windows build machine.
    If you use the latest (always up to date) version from here (which would be my suggestion): there might be issues on the buildbox and I'd have to look into it. I'm too lazy to test this builds for every arch, so let me know, if you are using it.
  3. #33
    February 2017
    Coding Issue
    Hey thansk for the great plugin! I have recently been altering the answercontacts script, however I am fairly basic when it comes to python. I have been trying to implement a bot known as chatterbot, however it seems as though the plugin does not reply to messages when I do this. Here is a snippet of the code:
    def onTextMessageEvent(self, schid, targetMode, toID, fromID, fromName, fromUniqueIdentifier, message, ffIgnored):
    (err, myid) = ts3lib.getClientID(schid)
    #CHATTERBOT BIT, When the next 3 lines are uncommented no reply is sent to the sending user...
    #from chatterbot import ChatBot
    #chatbot = ChatBot('Ron Obvious', trainer='chatterbot.trainers.ChatterBotCorpusTrain er')
    #response = chatbot.get_response(message)
    #Below is something that messages the user with a joke, this works when the below 2 lines of code are uncommented.
    #if message[0] != "-":
    # response = message + "... Don't copy me! Type - at the start of each message, to cancel this reply."
    So if anyone has any ideas to fix this, or anyone can alter the code/suggest something that would work -Essentially want something that will autoreply to a user with an AI Response, then I would be extremely thankful! Regards, Jack
  4. #34
    September 2005
    Germany / Dortmund
    1,376
    Is chatterbot installed in pyTSon's site-packages (Go to Plugins -> pyTSon -> Settings -> General -> Site packages -> Add)? Even if it's installed on your systems python installation, pyTSon won't notice that!
    Is there any output in the clientlog?
    P.S.: Please use code tags especially when posting python code!
    P.P.S: Sorry for the late answer, I just didn't notice your post.
  5. #35
    December 2015
    7
    Running win64, latest update of ts and getting the error when installing the 64bit version of the plugin:
    This add-on is not available for your platform.
  6. #36
    September 2005
    Germany / Dortmund
    1,376
    Sounds like a myteamspeak issue, I've always uploaded a build for each available desktop platform.
    The client log might be a bit more verbose about what's wrong.
    You can try to download it with your browser from myteamspeak.com (latest release is currently pending, so you'll get version 1.2.1).
    You can download the latest release from Github or the most recent updates from my download page.
  7. #37
    March 2019
    onClientMoveEvent only works on myself, is there something similar which also works for other people joining the channel which i am currently in?
    Is it possible to run a function when a user joined the channel which i am currently in? onClientMoveEvent only works on myself right? And is it possible to know who is talking?
  8. #38
    September 2005
    Germany / Dortmund
    1,376
    Please decide first, if you wanna communicate here or on github.
    See https://github.com/pathmann/pyTSon/issues/115
  9. #39
    April 2019
    What is that error?
    I think you should update the API version to 22
  10. #40
    September 2005
    Germany / Dortmund
    1,376
    Nope, api version 21 is still supported.
    Check your log, there should be an error message.
    This might happen, when some needed resources are not found. So where did you download it (and how did you install it)?
  11. #41
    September 2005
    Germany / Dortmund
    1,376
    What are you trying to do and how?
    Did you forget to add the log?
    edit by mod
    Post and user got removed from forum.
  12. #42
    March 2019
    Maskavas iela 12 k-1, Rīga, LV-1050
    Thanks for awesome plugin!
  13. #43
    June 2019
    PyTSon causes problems
    Hey guys.
    I wanted to add the PyTSon plugin and done so just after I found it in the addons-browser. After installing PyTSon my Teamspeak≥-Client keeps crashing.
    To avoid it from crashing, I already deleted all the PyTSon related files, but it keeps installing itself whenever I start my Teamspeak≥-Client again.
    Turning my internet off helped to not get any crashes again, but as soon as I'm turning it on again, my client crashes, cause PyTSon gets installed.
    I dont wanna uninstall the whole client and lose important chats etc or have even more work, just cause it keeps installing himself.
    Anyone here able to help me out? It would be enough to get rid of PyTSon. I dont need it to be running
    Thanks already!
  14. #44
    June 2019
    It's a pretty urgent problem.
    What file in Teamspeak allows automatic updates of plugins? It keeps downloading and installing itself after my manuel removement. A reinstallation with keeping the config after removing all the PyTSon files still gets me the same result.
    Help pls!
  15. #45
    September 2005
    Germany / Dortmund
    1,376
    Instead of deleting it manually, just uninstall it from the addons section.
    EDIT: If you even can't get to the plugins settings, start the client with all plugins disabled. If I remember correctly, there is a start parameter for the TS3 client to achieve that.
  1. [RELEASE]Now Playing Plugin
    By Screech in forum Client Plugins / Lua Scripts
    Last Post: February 3rd, 2018, 02:59 AM
  2. [Release] VLC Mute Plugin
    By SilentStorm in forum Client Plugins / Lua Scripts
    Last Post: April 30th, 2017, 09:20 PM
  3. [Release]LoLRandomizer Plugin
    By mJrA83 in forum Client Plugins / Lua Scripts
    Last Post: January 13th, 2015, 05:06 PM
  4. [Release] AutoAway plugin
    By plamen in forum Client Plugins / Lua Scripts
    Last Post: March 14th, 2014, 09:05 PM
  5. [RELEASE] Another TS3 Overlay Plugin
    By MarkR in forum Client Plugins / Lua Scripts
    Last Post: January 14th, 2011, 08:25 AM
