Results 1 to 3 of 3
    September 2005
    Germany / Dortmund
    1,376
    [client] processCommand not called for active plugin
    I have this situation:
    In my plugins directory are two plugins with the same commandKeyword, one is active, the other is not activated.
    Now if I try to execute a command, the client does not call the processCommand callback of the active one. I get the error "Invalid command or missing parameters". If I delete the lib of the non-active plugin, all works fine.
    Don't know what the client should do, if there are two active plugins with the same commandKeyword (and I didn't test this situation), but if there is an active plugin, it should be called.
    Happens at least on linux amd64.
    May 2016
    Idar-Oberstein
    163
    Well, generally speaking, thou shalt not create plugins with identical command keywords.
    However, I'm getting the scent this has rather sth. to do with pyTSon, doesn't it?
    My least restrictive idea for handling the case of both being enabled would be to change keyword to a list by priority, decide by that - if it's on the same position deny both.
    That'd probably happen independent of the enabled state of plugins to have consistency on runtime.
    September 2005
    Germany / Dortmund
    1,376
    Quote Originally Posted by thorwe View Post
    Of course, you should't.
    Well, I ran into this while testing pyTSon, yes. But it does have nothing to do with the internals of it. I guess it can happen with the test plugin compiled into two versions of it.
    I don't know if it is necessary to even care about it (the user got the responsibility to care about equal commandKeywords).
    My point was the situation, if only one of them is active. In fact, it took me some time to find out, why the **** processCommand is not called
  1. LUA PLUGIN: Submenu for each active module loaded
    By polski in forum Suggestions and Feedback
    Last Post: August 11th, 2018, 11:59 PM
  2. Camera in use when TS-Client is active
    By jimboberlin in forum Windows
    Last Post: July 27th, 2015, 02:07 PM
  3. G15 - Plugin won't stay active
    By MatthewH12 in forum Windows
    Last Post: December 5th, 2010, 06:30 AM
  4. Plugin that lowers the sounds of all active applications except TeamSpeak 3
    By Artyom.Topchyan in forum Client Plugins / Lua Scripts
    Last Post: October 13th, 2010, 08:06 PM
