Hey guys,
I have run out of friends to ask regarding how to fix this issue. Hopefully, one of you can help me out.
-I used to have a Razer Kraken Pro Headset (wired), which worked above-average on teamspeak and Skype.
-I replaced it due to wanting to go Wireless + wear in the ear cups.
-I bought a Razer Man O' War Headset (wireless). For those not familiar, its Razer's best headset.
-It works perfectly on Skype, with zero background noise, etc. Audio is excellent, Mic Quality is excellent.
-It works barely on Teamspeak. I am extremely quiet, and there is a lot of other noise. (not background noise, just a weird amount of random-ass noise.)
-As a result, talking with me on TS is impossible, as the distortion is painful to listen to.
some helpful information
-I run TS3, the latest version.
-All of my drivers (including those relating to sound) are up-to-date.
-Headset works fine on all other applications and browsers (other than TS).
-I have tried changing my capture and microphone devices on TS Settings to the headset I am using.
-This is NOT Bluetooth, it rather involves a small chip put into a USB drive, which produces a wireless signal for the headset to use.
So now I ask, how do I fix this, if there exists a method by which to? Anyone got any ideas?
Thanks,
Ryan
