Hello!
I've been using Teamspeak for a while now, and it has been quite successful thus far. I have used a Razer Kraken Pro headset, and there have been no issues. If anything, quality was better on Teamspeak than elsewhere. That being said, three years of frequent use had worn the device out, and I needed to buy a new one. I did so late last week, in the form of a Razer Man O' War. It should, based on specs, be better in all metrics, while being wireless. On Skype, for instance, I have been told that my audio is nearly flawless, with background noise being entirely shut out. The issue comes ONLY when I go to Teamspeak.
When I do, I am told it is not very good. Anyone know if there is a special step I am missing that I need for Wireless headphones? It is important to note that I already changed the microphone and payback devices both to the Man O' War, so there should be no problems in that regard.
Some Information That MIGHT Help.
This headset is NOT Bluetooth. It connects via a wireless chip one inserts into the USB Drive, which allows the headset to connect to the computer. Again, no Bluetooth is involved.
I recently set up Razer Surround Sound, but I have tried disabling that to fix the issue, and it persisted, so I turned it back on ......
If you guys need more information, I am happy to relay it!
Thanks for all the help in advance,
Ryan
