Results 1 to 4 of 4
    October 2016
    Failed to connect to serve (PLEASE HELP ME)
    Good evening, I'm trying to get into a TS server where there are my friends connected but I get this error:<21:20:16> Trying to resolve hostname udn.verygames.it
    <21:20:20> Trying to connect to server on udn.verygames.it
    <21:20:26> Failed to connect to server
    to log client I am attaching the file. Thank you so much for your time.
    CLIENT LOG:
    24/10/2016 19:54:10 Info TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
    24/10/2016 19:54:10 Info SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    24/10/2016 19:54:10 Direct Sound Debug setting timer resolution to 1ms
    24/10/2016 19:54:10 Info *** Time [SPAWN_EVENTCONVERTER]: 108
    24/10/2016 19:54:10 Info Loading plugin: clientquery_plugin
    24/10/2016 19:54:10 Info Loading plugin: lua_plugin
    24/10/2016 19:54:10 Info Loading plugin: teamspeak_control_plugin
    24/10/2016 19:54:10 Info Loading plugin: test_plugin
    24/10/2016 19:54:10 Info Loading plugin: ts3g15
    24/10/2016 19:54:10 Query Info listening on 127.0.0.1:25639
    24/10/2016 19:54:11 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    24/10/2016 19:54:11 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    24/10/2016 19:54:11 Info *** Time [SERVERVIEW_ACTIONS]: 106
    24/10/2016 19:54:11 Info *** Time [SERVERVIEW]: 142
    24/10/2016 19:54:11 Info *** Time [SERVERVIEWMANAGER]: 311
    24/10/2016 19:54:11 Input Info Default monitoring enabled
    24/10/2016 19:54:11 Info *** Time [MAINWINDOW]: 942
    24/10/2016 19:54:11 Info *** Time [INIT]: 943
    24/10/2016 19:54:11 ClientUI Info Qt version: 5.5.1
    24/10/2016 19:54:11 ClientUI Info Using configuration location: C:\Users\Term02\AppData\Roaming\TS3Client\settings .db
    24/10/2016 19:54:12 ClientUI Info Last update check was: lun ott 24 20:05:17 2016
    24/10/2016 19:54:12 Info Statistics report: User previously denied participation
    24/10/2016 19:54:12 Newsticker Info Newsticker next check: lun ott 24 22:08:49 2016
    24/10/2016 19:54:21 ClientUI Info Connect to server: udn.verygames.it
    24/10/2016 19:54:21 ClientUI Info Trying to resolve udn.verygames.it
    24/10/2016 19:54:21 TSDNS Info DNS resolve successful, "udn.verygames.it"=164.132.93.40
    24/10/2016 19:54:25 ClientUI Info Lookup finished: 164.132.93.40 9987 udn.verygames.it 0 0
    24/10/2016 19:54:25 ClientUI Info Resolve successful: 164.132.93.40:9987
    24/10/2016 19:54:25 ClientUI Info Blacklist check ok
    24/10/2016 19:54:25 ClientUI Info Initiating connection: 164.132.93.40:9987 udn.verygames.it
    24/10/2016 19:54:25 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    24/10/2016 19:54:25 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    24/10/2016 19:54:25 Windows Audio Session Debug WAS:penDevice-enter
    24/10/2016 19:54:25 Windows Audio Session Debug WAS Buffer size: 3840
    24/10/2016 19:54:25 Windows Audio Session Debug WAS:penDevice-leave
    24/10/2016 19:54:25 Windows Audio Session Debug WAS::startDevice-enter
    24/10/2016 19:54:25 Windows Audio Session Debug WAS::startDevice-leave
    24/10/2016 19:54:26 Windows Audio Session Debug WAS Buffer size: 960
    24/10/2016 19:54:26 Windows Audio Session Debug WAS:penDevice-leave
    24/10/2016 19:54:26 PreProSpeex Info Speex version: speex-1.2beta3
    24/10/2016 19:54:26 Windows Audio Session Debug WAS::startDevice-enter
    24/10/2016 19:54:26 Windows Audio Session Debug WAS::startDevice-leave
    24/10/2016 19:54:26 Windows Audio Session Debug WAS::associateAECDevice-enter
    24/10/2016 19:54:26 Windows Audio Session Debug WAS Buffer size: 3840
    24/10/2016 19:54:26 Windows Audio Session Debug WAS::associateAECDevice-leave
    24/10/2016 19:54:26 Windows Audio Session Debug Got 3 or more rendering spaces in same loop 1920 3840 1920
    24/10/2016 19:54:26 ClientUI Info Connect status: Connecting
    24/10/2016 19:54:31 ClientUI Info Connect status: Disconnected
    24/10/2016 19:54:31 ClientUI Info Failed to connect to server, want autoreconnect = 0
    24/10/2016 19:54:33 TSDNS Info SRV DNS resolve unsuccessful for "_ts3._udp.udn.verygames.it"
    4,367
    Your DNS server does not resolve SRV RR. Connect to this:
    164.132.93.40:52982
    October 2016
    164.132.93.40:52982
    How did you come up with this IP? I'm having the same issue with sob-gaming.win
    Cheers!
    31/10/2016 22:04:48 Info TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
    31/10/2016 22:04:48 Info SystemInformation: Windows 10 (14393) x64 (AMD or Intel) Binary: 64bit
    31/10/2016 22:04:48 Info Using hardware aes
    31/10/2016 22:04:48 Direct Sound Debug setting timer resolution to 1ms
    31/10/2016 22:04:48 Info Loading plugin: clientquery_plugin
    31/10/2016 22:04:48 Info Loading plugin: lua_plugin
    31/10/2016 22:04:48 Info Loading plugin: teamspeak_control_plugin
    31/10/2016 22:04:48 Info Loading plugin: test_plugin
    31/10/2016 22:04:48 Info Loading plugin: ts3g15
    31/10/2016 22:04:48 Query Info listening on 127.0.0.1:25639
    31/10/2016 22:04:48 Overwolf Debug Detected Overwolf start
    31/10/2016 22:04:49 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    31/10/2016 22:04:49 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    31/10/2016 22:04:49 Info *** Time [SERVERVIEWMANAGER]: 197
    31/10/2016 22:04:49 InputDevices Info Input device name:
    31/10/2016 22:04:49 Input Info Default monitoring enabled
    31/10/2016 22:04:49 Info *** Time [MAINWINDOW]: 503
    31/10/2016 22:04:49 Info *** Time [INIT]: 504
    31/10/2016 22:04:49 ClientUI Info Qt version: 5.5.1
    31/10/2016 22:04:49 ClientUI Info Using configuration location: C:\Users\Main\AppData\Roaming\TS3Client\settings.d b
    31/10/2016 22:04:49 ClientUI Info Last update check was: Mon Oct 31 17:17:32 2016
    31/10/2016 22:04:49 Info Statistics report: Not yet, next report on Fri Nov 4 01:14:00 2016
    31/10/2016 22:04:50 Newsticker Info Newsticker next check: Mon Oct 31 18:17:34 2016
    31/10/2016 22:04:56 ClientUI Info Connect to server: sob-gaming.win
    31/10/2016 22:04:56 ClientUI Info Trying to resolve sob-gaming.win
    31/10/2016 22:04:56 TSDNS Info SRV DNS resolve unsuccessful for "_ts3._udp.sob-gaming.win"
    31/10/2016 22:04:56 TSDNS Info No SRV TSDNS found at "_tsdns._tcp.sob-gaming.win"
    31/10/2016 22:04:56 TSDNS Info DNS resolve successful, "sob-gaming.win"=162.255.119.248
    31/10/2016 22:04:58 ClientUI Info Lookup finished: 162.255.119.248 9987 sob-gaming.win 0 0
    31/10/2016 22:04:58 ClientUI Info Resolve successful: 162.255.119.248:9987
    31/10/2016 22:04:58 ClientUI Info Blacklist check ok
    31/10/2016 22:04:58 ClientUI Info Initiating connection: 162.255.119.248:9987 sob-gaming.win
    31/10/2016 22:04:58 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    31/10/2016 22:04:58 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    31/10/2016 22:04:58 Windows Audio Session Debug WAS:penDevice-enter
    31/10/2016 22:04:58 Windows Audio Session Debug WAS Buffer size: 1056
    31/10/2016 22:04:58 Windows Audio Session Debug WAS:penDevice-leave
    31/10/2016 22:04:58 Windows Audio Session Debug WAS::startDevice-enter
    31/10/2016 22:04:58 Windows Audio Session Debug WAS::startDevice-leave
    31/10/2016 22:04:58 Windows Audio Session Debug WAS Buffer size: 984
    31/10/2016 22:04:58 PreProSpeex Info Speex version: speex-1.2beta3
    31/10/2016 22:04:59 ClientUI Info Connect status: Connecting
    31/10/2016 22:05:04 ClientUI Info Connect status: Disconnected
    4,367
    24.25.203.130
    Your IP is just plain outdated.
    I suggest you change your nameservers, e.g. to Google's nameservers (8.8.8.8 and 8.8.4.4) in your Windows network connection settings.
  1. Fail to connect to serve
    By matewoth in forum Windows
    Last Post: September 16th, 2016, 08:57 PM
  2. Replies: 1
    Last Post: September 20th, 2015, 12:09 PM
  3. Replies: 12
    Last Post: September 1st, 2014, 06:20 AM
  4. Failed to Connect to Serve on Windows 7
    By Anriko in forum Windows
    Last Post: January 8th, 2014, 10:38 AM
