Results 1 to 1 of 1
    August 2016
    SDK PTT Delay stops audio transmission though it shouldn't
    Test setup:
    Voice input set to use PTT with a PTT-delay of 3 seconds.
    A Plugin that has an Additional PTT Key Handler as described in the SDK docs.
    User presses his normal PTT key and then let's go again.
    While the PTT-delay is running the plugin calls
    ts3client_setClientSelfVariableAsInt(scHandlerID, CLIENT_INPUT_DEACTIVATED, INPUT_ACTIVE)
    When the PTT-delay runs out the clients stops Transmitting although CLIENT_INPUT_DEACTIVATED is still set to INPUT_ACTIVE. So it should still be transmitting till the Plugin calls
    ts3client_setClientSelfVariableAsInt(scHandlerID, CLIENT_INPUT_DEACTIVATED, INPUT_DEACTIVATED).
    In my case the Plugins PTT is caused by a Radio thats used in a game. When player uses the Radio button In-game Sending in Teamspeak is enabled. And it should stay enabled till the button is let go. But when player has a high PTT delay and presses the Radio button shortly after letting his PTT go. To talk over Radio instead of Direct voice. That bug occurs
  1. Sub Admin can add permissions, but he shouldn't be able
    By AGamer in forum Permission System
    Last Post: October 3rd, 2016, 07:19 PM
  2. Replies: 8
    Last Post: July 13th, 2016, 03:19 PM
