Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    February 2017
    TeamSpeak 3 Client not responding after connecting
    The issue is when I launch TeamSpeak, the client will open and I am able to see everything that I need to connect to. Once I type the server IP into the connect field, the whole client will freeze and go into not responding. Issue started this morning and I can't remember if it was after an update or not.
    Troubleshooting:
    Cleared AppData folder
    Cleared temp files
    Uninstalled and reinstalled
    Restarted computer
    Restarted Network
    Ran as admin
    Tried different network (Wireless and wired)
    Computer running Windows 10 64-bit.
  2. #17
    January 2013
    Thüringen
    329
    Do you get an crash dump file ?
  3. #18
    April 2017
    Teamspeak 3 stops responding when I try to connect to any server. HELP!
    So, I installed Teamspeak 3 last night and I tried to open it up and tried to connect to a server it freezes and stops responding. I have no idea whats wrong with it so if you guys could help me that would be great!
  4. #19
    18,015
    You gave 0 details about your system or client
    Please give us more details
    Are you using an laptop or motherboard from MSI?
    http://forum.teamspeak.com/threads/1...848#post431848
    Or which hardware do you use?
  5. #20
    April 2017
    TeamSpeak freezes when I try to connect to a server
    Hey,
    Sorry for my bad english,
    when i try to cennect to any Server TS3 freez and i can only close it with Task Manager.
    Tryed:
    Restart PC
    Reinstalled TS3 and updated.
    Deaktivated Avast
    DMP File: http://www66.zippyshare.com/v/AZUy0OlG/file.html
  6. #21
    January 2017
    im having the same issue no crash dump file or anything just not responding tried all troubleshooting
  7. #22
    May 2017
    Not responding after choosing to connect
    Can't connect to any TS server after installing the latest update. I have 3 servers in my bookmarks and none connect. I just watch the program eventually tell me it is not responding. I have uninstalled, uninstalled and deleted preferences and reinstalled. I have attached my logs from the last reinstall I did. I am running the app as administrator. I have tried to connect to any TS server and still the same.
  8. #23
    18,015
    Does it work when you use Direct Sound under "Tools -> Options -> Play/Capture" instead of Using Default (Windows Audio Session).
  9. #24
    May 2017
    TeamSpeak 3 crashes when connecting to server
    I've installed TeamSpeak 3 on my new desktop but as soon as I try to connect to a server, the program stops working. After restarting my computer, it sometimes seem to work but after +-15min my mic and speakers stop working. I see other people talking and I can see myself talking but others can't hear me and I can't hear them anymore. When I try to reconnect or restart the client, it crashes again when trying to connect.
    I've tried to reinstall the client completely but it keeps crashing.
    Hope someone can help me out!
  10. #25
    May 2017
    Still having this problem, anyone that can help me?
  11. #26
    18,015
    Quote Originally Posted by Mr_Eoki View Post
    There are already answers that can be found in that thread.
    And you gave not enough details (no logs, no devices, no operation system or client version) to see what is happening.
    Sometimes it works for minutes? Sounds like your device does unplug.
  12. #27
    May 2017
    I have MSI indeed, I uninstalled Nahimic completely and it solved it for 1 day. Next day it happend again. I don't have Direct Sound as an option tho.
  13. #28
    18,015
    Strange.
    Updating Nahimic should solve also have solved the problem.
    You do not have Direct sound as a choice? This nearly* impossible on Windows.
    Install latest Windows Updates and drivers on your system.
    ps you still gave no details about your system, device or logs.
  14. #29
    July 2017
    Client crashes/freezes whenever I try to login to server
    Teamspeak was working fine yesterday but today I have been unable to log onto Teamspeak I can open the programme and change options etc but as soon as I try to log on it simple freezes. I have uninstalled and reinstalled the client and turned off my computer but the problem remains.
    Client Log below;
    13-Jul-17 20:52:49 Info TeamSpeak 3 Client 3.1.4.2 (2017-06-28 10:01:41)
    13-Jul-17 20:52:49 Info SystemInformation: Windows 10 (15063) x64 (AMD or Intel) Binary: 32bit
    13-Jul-17 20:52:49 Info Using hardware aes
    13-Jul-17 20:52:49 Direct Sound Debug setting timer resolution to 1ms -
    13-Jul-17 20:52:49 ClientUI Info OpenGL Info: LibGLES, Vendor: Google Inc., Renderer: ANGLE (NVIDIA GeForce GTX 1070 Direct3D11 vs_5_0 ps_5_0), Version: OpenGL ES 2.0 (ANGLE 2.1.99f075dade7c)
    13-Jul-17 20:52:49 Addons Info Checking for addon updates...
    13-Jul-17 20:52:49 Plugins Info Loading plugin: gamepad_joystick_win32.dll
    13-Jul-17 20:52:49 Gamepad Plugin Info Found client raw input wnd proc
    13-Jul-17 20:52:49 Gamepad Plugin Info Cleared device list
    13-Jul-17 20:52:49 Plugins Info Loading plugin: clientquery_plugin_win32.dll
    13-Jul-17 20:52:49 Query Info listening on 127.0.0.1:25639
    13-Jul-17 20:52:49 Plugins Info Loading plugin: teamspeak_control_plugin_win32.dll
    13-Jul-17 20:52:49 Addon Info Addon up to date.
    13-Jul-17 20:52:49 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    13-Jul-17 20:52:49 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    13-Jul-17 20:52:49 Info *** Time [MAINWINDOW]: 296
    13-Jul-17 20:52:49 Info *** Time [INIT]: 296
    13-Jul-17 20:52:49 ClientUI Devel Notifications init: Soundpack path: C:/Program Files (x86)/TeamSpeak 3 Client/sound\default
    13-Jul-17 20:52:49 ClientUI Info Qt version: 5.6.1
    13-Jul-17 20:52:49 ClientUI Info Using configuration location: C:\Users\Tom\AppData\Roaming\TS3Client\settings.db
    13-Jul-17 20:52:50 Bookmarks Info Collecting autoconnect bookmarks
    13-Jul-17 20:52:50 ClientUI Info Last update check was: Thu Jul 13 21:18:48 2017
    13-Jul-17 20:52:50 Info Statistics report: Not yet, next report on Mon Jul 24 21:21:15 2017
    13-Jul-17 20:52:51 Newsticker Info Newsticker next check: Thu Jul 13 22:19:49 2017
  1. [Resolved] teamspeak 3 application android crash crash crash
    By hycksou in forum Android
    Last Post: July 5th, 2017, 06:05 PM
  2. Replies: 0
    Last Post: November 18th, 2014, 09:40 PM
