Page 7 of 8 FirstFirst ... 5678 LastLast
Results 91 to 105 of 107
  1. #91
    December 2004
    RF
    3,008
    If you want a memorable name, you will need A/AAAA record in any case.
    Even if you are using default port, chances are, you will not be hosting your TS server at the same place you are hosting your website.
    The use of SRV RR frees your hands.
  2. #92
    October 2015
    UK
    18
    Ok so I did what you said Chris and now none of us can connect so can I just verify this. We have a domain BinaryCombat.com and we use the subdomian ts.binarycombat.com to connect to TeamSpeak the way I set it up
    A record - ts.binarycombat.com. 14400 IN A teamspeak IP
    _ts3._udp.ts.binarycombat.com. 3600 IN SRV Priority: 0
    Weight: 5
    Port: TS port
    Target: ts.binarycombat.com
    This did not work for us so I have now changed the A record of ts.binarycombat.com back to the main domain IP, will that work? Lol
  3. #93
    4,368
    If 109.70.148.9:9007 is your IP, it's wokring.
  4. #94
    October 2015
    UK
    18
    No that is our website IP
  5. #95
    4,368
    Then set the IP for ts.blablabla as an A record (where you already set that IP). SRV is correct otherwise.
  6. #96
    October 2015
    UK
    18
    So set the A record IP as the TS server IP right?
  7. #97
    4,368
    Yes, A record of the TS subdomain.
  8. #98
    May 2013
    I did everything correctly as you can see in the image below but anyway it does not work!
    ts3.mydomain.com - 4321= port
    And if I leave it as just and use the tsdns server:
    The deprecated configuration message is still displayed
  9. #99
    4,368
    Quote Originally Posted by latters View Post
    it does not work!
    Lol.
    Instead of your domain shbrasilhost.com, you say mydomain.com in your post. Why's that?
  10. #100
    May 2013
    Lol.
    I simply edited why I did not want my domain to appear.
    Can you help me with the question above?
  11. #101
    4,368
    Right now, you set up only a TSDNS SRV record pointing to shbrasilhost.com, but no such A or AAAA record exists.
    Basically, you should see the FAQ and read (and understand!) the corresponding RFCs like 2782.
  12. #102
    May 2013
    I did not understand what you wanted to say, as you can see in the image the settings are correct, and after adding _tsdns none of the domain addresses can connect to the servers.
  13. #103
    December 2004
    RF
    3,008
    If settings were correct, it would have worked.
    Now, you can stop lying to us and show actual settings, or we won't be able to help you.
  14. #104
    6,079
    Your image in fact contains several warnings, one of which is the reason. It was also mentioned by numma in the quote.
    You're pointing your SRV record to a name that doesn't exist. SRV target name must have at least one A/AAAA record as specified in the RFC.
  15. #105
    May 2013
    I apologize if anyone felt offended that I asked for help.
    Chris, can I send you an email with my account access data? And you create the configuration for me in my cloudflare domains?
  1. Failing to connect more than once.
    By OZ1BPZ in forum Client Support
    Last Post: December 13th, 2016, 05:31 PM
  2. Failing to connect
    By dranlo in forum Windows
    Last Post: September 18th, 2013, 07:01 AM
  3. TeamSpeak 3 Client Update failing at 59%.
    By rifter in forum Windows
    Last Post: May 17th, 2011, 05:24 PM
  4. [Solved] Server working, Client failing.
    By Rednekk in forum Client Support
    Last Post: February 1st, 2010, 12:57 PM
