Results 1 to 3 of 3
    January 2017
    Connection problem
    Hello. Since I have installed the app, it shows me the error "error failed connection initalisation", when I want to join a server. It worked only for one day..and then I had the problem again.
    What's that and how i can fix it?
    Greetings
    January 2017
    New zealand
    Connection probs since update on iphones
    Ok i think i just sorted mine on my phone access your ts on ph. If you can connect to public server straightaway sweet but if your having trouble connecting to your private server i did this
    Push and hold on your server. Go to edit. Then scroll to the box sync and tick it
    Then go out and your server should be listed under syncd. If it is you should then be able to connect
    It worked for me hope same for you...
    18,003
    From the missing details i would guess SRV problems on target Domain.
    The most common reason why you can't connect nowadays is that the Host does use an invalid SRV setting.
    The host did not add at least one valid A or/and AAAA record for target Domain
    More details here:
    http://forum.teamspeak.com/threads/1...ter-client-3-1
