Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 88
  1. #31
    18,513
    The second picture looks like you tried to install a version that is not made for your system.
    Make sure you download the right version.
  2. #32
    February 2017
    Can anyone help me?
    I just want to upload my ts3 version, but when i try to open the updated version, it send this:
    The program can not start because it is missing api-ms-win-crt-runtime-l1-1-0.dll in the system. Try reinstalling the program to correct this problem.
    I download this .dll file, when i put it on Ts3 folder, it sends this:
    The application could not start successfully (0xc0000142). Click OK to close it.
    What can i do? I wan't to open my ts3, but i can't. I tried to search it on Google, i downloaded a Registry Cleaner, but it don't work, i tried to reinstall it, but it don't work, i tried to download other Ts3 version older than 3.1.1 (Recent version) and it didn't work either.
    What can i do?
  3. #33
    February 2017
    Not true
    You don't have the latest Windows updates installed.
    Especially update KB2999226 is missing. It's one of the updates, that get installed by default.
    https://support.microsoft.com/en-us/...ime-in-windows
    Solution: Install latest Windows updates. You could try to download and install the vcredist again (please reboot after setup).
    Our download:
    http://dl.4players.de/ts/client/redist/
    Official download from Microsoft:
    Visual C++ Redistributable for Visual Studio 2015 (64-bit)
    Visual C++ Redistributable for Visual Studio 2015 (32-bit)
    This is false I have the latest update still getting this error please help.
  4. #34
    6,079
    Quote Originally Posted by Synnek_ View Post
    The quoted text is referring to Windows updates, not the TeamSpeak client.
    In addition please try installing the linked downloads. Whether to use 32 or 64 bit depends on which Client you're using.
  5. #35
    March 2017
    TEamspeak not opening in Win 7
    Hey,
    I updated Teamspeak 3 and now it cant be started.
    If i start it, it says "Programm can not be runned, because "Api-ms-win-crt-runtime-l1-1-0.dll" is missing. Please reinstall.
    Reinstalled it multiple times, still dont work. Dont work when i open as Admin, either.
    Can some1 help me?
  6. #36
    March 2017
    [PROBLEM] TEAMSPEAk3 CLIENT OPEN
    I have a problem. When i opened TeamSpeak 3 , i see that.
    What do to solve it?
    http://imgur.com/a/6lLuG
  7. #37
    March 2017
    I can't install teamspeak 3 because of this.
    http://prnt.sc/en6enp
    I don't know what to do but if you need any screenshots,tell me then i will show it to you!
  8. #38
    March 2017
    I downloaded [Visual C++ Redistributable Visual Studio 2015].. http://prntscr.com/en7q62
    Can you help me to unistall all teamspeak3 information then reinstall if i can use teamspeak 3 again.
  9. #39
    18,513
    Uninstalling TeamSpeak will not help here.
    You have to uninstall the faulty vcredist 2015 first before you can reinstall it.
  10. #40
    March 2017
    I can't update ts3 client since the last 3.1 version... ._.
    I get this error after trying to update the client ... Click image for larger version.
    Any help please? my pc properties : Click image for larger version.
  11. #41
    April 2017
    system error
    i get this error when opening ts newest version
  12. #42
    April 2017
    I cannot get into TeamSpeak
    Hello everybody. I came here to ask if anyone knows how to resolve the issue ive been having.
    So whenever I click to go onto teamspeak, an error message saying: The program cant start because api-ms-win-crt-runtime-1-1-0.dll is missing from your computer.
    I have heard from some people that this means that since I have windows 8 and not windows 10, it does not allow me to go onto teamspeak. However, I am not really capable of upgrading at the moment. If there is a way around it it would be nice to know.
    If you can help me out that would be great! Thanks.
  13. #43
    April 2017
    ts3client_win64.exe - System Error
    I a trying to run TeamSpeak 3 client on my computer. The error is receive is "The program can't start because api-ms-win-crt-runtime-l1-1-0.dll is missing from your computer. Try reinstalling the program to fix this problem.
    I researched the issue under forums in TeamSpeak and it is telling me I am having a missing update (KB2999226). It gives a link to Microsoft for this update. When I download the update for x64-based versions of Windows 8.1 and try to run it, the installer tells me the update is not applicable to my computer, so that was a bust. I am taking that up with Microsoft.
    The other option TeamSpeak suggest is downloading VC++ Redistributable From Microsoft Website. Again, I follow this link and download the x64 version, run the download and restart my computer. I try to run TeamSpeak3 client on my computer after this download and still get the error: "The program can't start because api-ms-win-crt-runtime-l1-1-0.dll is missing from your computer. Try reinstalling the program to fix this problem.
    I have done this several times with no luck. Does anyone have a solution to this error?
  14. #44
    April 2017
    Please help! missing api-ms-win-crt-runtime-l1-1-0.dll
    I just buy new PC and i cant start TS3. Always writte me somwthing about missing api-ms-win-crt-runtime-l1-1-0.dll. I tried to reinstal TS, tried to uninstall Microsoft Visual C++ Redistributable (x64) and still not working. Can someone tell me why?
    Thanks, have a nice day
  15. #45
    May 2017
    TeamSpeak won't load on Windows
    Hi guys, I recently downloaded TeamSpeak, and it doesn't load on my computer. When I go open up TeamSpeak I get an error 'The procedure entry point ucrtbase.abort could not be located in the dynamic link library api-ms-win-crt-runtime-l1-1-0.dll'
    Does anyone have a solution how to fix this? I've tried to re-install numerous times, and it's still not being resolved.
    Thanks!
  1. TS3-Client "runtime-limited" ?
    By dachs in forum Windows
    Last Post: October 25th, 2011, 02:55 PM
  2. TeamSpeak 3 Client - Runtime Error -
    By lutzen in forum Windows
    Last Post: June 27th, 2011, 02:54 PM
