Results 1 to 7 of 7
    January 2017
    SRV Problem: "Failed to connect to server"
    We currently host our servers through a shared network, and it works fine. I've attached the IP and the port to the sub-domain, thus meaning I have had to add a new host / SRV record into my domain.
    It works, however joining is not always 100%. It has a high percentage rate of "[Failing] to connect to server", but will connect sometimes, like this:
    Running a TeamSpeak server, I can't have people joining with the sub-domain to connect and failing, and having to retry until they get in. I need them to be able to connect 100% of the time using the sub-domain. That said, here's what my sub-domain records look like(the URL's are correct, because like I said, I can connect sometimes):
    Here's what my DNS options look like:
    http://i.imgur.com/QNARaq4l.png
    http://i.imgur.com/2Cnxv52l.png
    Any help is appreciated, thank you.
    4,368
    How should we help you if you censor all important information?
    January 2017
    the important information is just my IP to the TeamSpeak server, my website URL and my website url with the sub-domain attached to it (ts.*websiteurl*.com). It's not needed, and like I said in my post, the URL's are correct, because like I said, I can connect sometimes therefore, it's not my urls that are the problem and are not needed.
    January 2017
    Italy
    10
    Have you read this thread?
    https://support.teamspeakusa.com/ind...ns-srv-records
    Have you added a SRV record for our TSDNS server?
    Have you configured our TSDNS server?
    I use this DNS configuration
    sub.domain.extension A *teamspeak-ip-address*
    _ts3._udp.domain.extension. SRV 0 5 *voice port* sub.domain.extension.
    _ts3._udp.sub.domain.extension. SRV 0 5 *voice port* sub.domain.extension.
    _tsdns._tcp.domain.extension. SRV 0 5 *tsdns port* sub.domain.extension.
    _tsdns._tcp.sub.domain.extension. SRV 0 5 *tsdns port* sub.domain.extension.
    and this TSDNS configuration
    domain.extension=NORESPONSE
    sub.domain.extension=*teamspeak-ip-address*
    *.domain.extension=NORESPONSE
    This configuration allows you and other to connect to the server only with a subdomain for example ts3.domain.extension
    January 2017
    Quote Originally Posted by jeth02 View Post
    I can connect to the teamspeak with the domain (e.g ts.*mydomain*.com, works) It just sometimes fails when connecting, so it's not 100%.
    4,368
    Quote Originally Posted by Wandle View Post
    I guess help is not needed then either.
    January 2017
    Italy
    10
    I think this is a problem from registrar, maybe the propagation of the DNS.
    Try to move the DNS configuration on Cloudflare, disable traffic through Cloudflare on all record.
  1. Replies: 0
    Last Post: February 11th, 2016, 03:24 PM
  2. Replies: 1
    Last Post: January 25th, 2016, 09:05 AM
  3. "Failed to connect" problem
    By Rameex in forum Server Support
    Last Post: July 28th, 2015, 11:58 AM
  4. Replies: 0
    Last Post: January 1st, 2014, 10:28 PM
  5. got problem "Failed to connect to server"
    By ZEYS79 in forum Client Support
    Last Post: November 19th, 2012, 09:23 AM
