Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    18,513
    Quote Originally Posted by Golden View Post
    Just founded the crashdump folder. I don't know how to upload a crash so you'll have to teach me. If you have skype just copy and pase this: *removed* (without the underscore) and search it on skype contacts.
    Press Go Advanced when writing a new post.
    Then press the clip (to the right from the smiley).
    Press on search and select the zip file.
    Press Upload and then Close the window.
    Finish your post.
    Quote Originally Posted by bagel View Post
    Is anything in progress?
    Not yet.
  2. #17
    October 2012
    33
    To get Hotkey functionality on Controllers, wheels, joysticks and the like you need to have the plugin enabled. It should've been installed automatically. Check if you have the "Gamepad and Joystick Hotkey Support" plugin installed (Tools -> Options -> Addons -> Plugins) and make sure it is enabled. If you don't search for Gamepad in Tools-> Options -> Addons -> Browse online and install that one. https://www.myteamspeak.com/addons/9...f-4cd53c886a8d
    It's only available on Windows though.
    Hi Chris,
    I have news this plugin not working to windows 7 only windows 10.Was tested in four different pc!
  3. #18
    18,513
    You are using the ps3 and the xbox (not xbox 360 & xbox one) gamepad?
    Are there official drivers out there?
    My guess in case you use tools to run these gamepads:
    These tools generate software keys and these software keys are not supported in our hotkey system.
  4. #19
    September 2011
    I had hotkeys as well for muting the sound and mic, but it stopped working in the 3.1.1.1 build.
    I could still set the hotkeys, but they won't work afterwards.
    I went back to the 3.1.0.1 build now and it works perfectly fine.
    Last edited by dante696; March 20th, 2017 at 02:02 PM. Reason: moved out of thread http://forum.teamspeak.com/threads/130029 . content is not the same
  5. #20
    18,513
    And which keys and keyboard have you used?
    Are you sure that the same hotkey profile is activated in your bookmark?
  1. [Discussion] TeamSpeak 3 Client 3.1.0 Release
    Last Post: February 1st, 2017, 10:18 PM
  2. Replies: 20
    Last Post: June 21st, 2012, 11:56 AM
  3. Replies: 9
    Last Post: April 23rd, 2012, 08:12 AM
  4. TeamSpeak 3 Client 3.0.5 Release Discussion
    By PeterS in forum Archive
    Last Post: March 11th, 2012, 10:27 PM
  5. Replies: 31
    Last Post: February 17th, 2012, 05:19 PM
