Results 1 to 6 of 6
    January 2017
    15
    TeamSpeak3 keeps crashing randomly (Fault Module: ucrtbase.dll)
    edit by staff
    Crash caused from 3rd party plugin 'Notifications'
    I have no idea why this is happening but i will try to provide debug information also but i hope this helps for now.
    Also i am using beta version i will try go back to stable version to see that only happens on beta.
    Description
    Faulting Application Path:	C:\Program Files\TeamSpeak 3 Client\ts3client_win64.exe
    Problem signature
    Problem Event Name:	BEX64
    Application Name:	ts3client_win64.exe
    Application Version:	3.1.1.0
    Application Timestamp:	589d7066
    Fault Module Name:	ucrtbase.dll
    Fault Module Version:	10.0.14393.0
    Fault Module Timestamp:	578997b5
    Exception Offset:	000000000006ea1e
    Exception Code:	c0000409
    Exception Data:	0000000000000007
    OS Version:	10.0.14393.2.0.0.768.101
    Locale ID:	1033
    Additional Information 1:	dac1
    Additional Information 2:	dac1a8442f172a83edad38eaffde7969
    Additional Information 3:	4b93
    Additional Information 4:	4b938cd9d8ef59a5b5f9e7270749d42d
    Extra information about the problem
    Bucket ID:	acdc0bcab697b42d4003822821f2ad7d (116330439945)
    18,153
    The posted windows crash report does not help us. It could be anything that causes this crash.
    Does the client create a crashdump (under %appdata%/TS3client/crashdumps)?
    Which version are you using?
    Did this work in older clients?
    Are you using any new or updated custom plugins?
    January 2017
    15
    Sorry for the delay, well yes there is crash dump (but i am not sure if they are related to my crashes if i found any new one i will post it) and plugins only few g-key , AutoAway, Connection History, Chatlog Viewer
    also the Connection History, Chatlog Viewer they are new and i made the AutoAway my self for the new version also the g-key was a old plugin that stopped working and i fixed it
    18,153
    Please attach this crashdump.
    In think one of the plugins does cause this crash.
    You may deactivate these for a while to test it on your own.
    January 2017
    15
    Yes i am waiting for like a new crash dump but there is none, just some other ones that i am not sure if they are related to this problem so i going to wait a bit for new crash dump
    January 2017
    15
    After testing few things i noticed Notifications plugin was causing the problem
  1. Replies: 3
    Last Post: May 12th, 2017, 04:07 AM
  2. Replies: 2
    Last Post: November 9th, 2016, 12:05 AM
  3. Teamspeak keeps randomly crashing
    By Chuckles in forum Off Topic
    Last Post: April 23rd, 2014, 02:44 PM
  4. My client randomly started crashing
    By shark03 in forum Windows
    Last Post: May 26th, 2011, 10:22 PM
