Results 1 to 2 of 2
    October 2015
    My hotkeys do not work on OS X with client 3.1.1
    Me again. Its broken again with the 3.1.1.1 update. In the past I was able to basically futz around with opening ControllerMate, rebooting, etc. and TeamSpeak would eventually start seeing my foot pedal again. None of that works with this update. CM works fine outside of TS. I even tried having CM generate a mouse click instead and TS didn't see it either.
    Going back to 3.1.0.1 still works but I have to tell it to ignore the fact prefs are incompatible. Where do you store your prefs so I can revert those too?
    Mac OS 10.12.3 now.
    18,513
    I moved your post out of http://forum.teamspeak.com/threads/121029.
    Client 3.1.1 (and newer) has a different hotkey system running as in the original report.
    Software generated keys (all operating systems) and Gamepad/Joysticks (Linux & Mac Os) are not supported in that hotkey system. Our developers are aware of this, but we can't say if this will be supported in the future.
    The config file is located under /Library/Application Support/TeamSpeak 3.
  1. Hotkeys don't work
    By Szczaff in forum Windows
    Last Post: November 27th, 2016, 06:03 PM
  2. Hotkeys sometimes work sometimes not
    By Gamecube in forum Windows
    Last Post: June 28th, 2015, 07:32 PM
  3. Hotkeys don't work at all
    By Nextelracer in forum Client Support
    Last Post: February 5th, 2014, 03:23 PM
  4. My Hotkeys Will not Work at All
    By NAHNEN in forum Bug Reports [EN/DE]
    Last Post: January 26th, 2014, 10:03 AM
  5. TeamSpeak 3 hotkeys do not work
    By TeddyBeertje in forum Windows
    Last Post: May 10th, 2011, 12:13 PM
