Results 1 to 10 of 10
    April 2015
    12
    Member add / remove power problem (failed on i_client_needed_permission_modify_power)
    Hello! I would like members of [game clan group] to be able to move [guest] group members into the [friend] group, but they're getting permission error with i_client_needed_permission_modify_power.
    Why do my [game clan group] members not able to assign [guest] into the [friend] group? Why is the error given related to the permission to modify the group? I don't want my clan members to be able to modify permissions of the groups, just add/remove members between the lower groups.
    Here are the groups I have, each with slightly lower permissions than the group above:
    Main Admin
    Jr Admin
    Game Clan Group
    Friend
    Guest
    Channel group permissions are the standard 4 and all of them have all of the "member" permissions removed in the Group>Modify list to make sure they don't override server group permissions.
    There are also no client permissions or channel involved, as the Group>Modify>"member" permissions are all removed as well.
    [jr admin]:
    member add: 70
    needed member add: 75
    member remove: 70
    needed member remove: 75
    i_client_needed_permission_modify_power: 75
    [game clan group]:
    member add: 60
    needed member add: 70
    member remove: 60
    needed member remove: 70
    [friend]:
    member add: [permission removed]
    needed member add: 60
    member remove: [permission removed]
    needed member remove: 60
    [guest]:
    18,151
    Remove i_client_needed_permission_modify_power from last 3 groups (also from Jr Admin in case this group can not modify permissions).
    Adding i_client_needed_permission_modify_power to all groups is not needed as long your non Admin groups do not have any i_client_permission_modify_power AND Grant values set on permissions.
    April 2015
    12
    Would I remove that permission from the Jr Admin group if I don't want them to be able to modify permissions?
    18,151
    No you would remove their i_permission_modify_power and/or i_channel_permission_modify_power and/or i_client_permission_modify_power or Grant on target permission.
    April 2015
    12
    Okay. I guess I don't understand why both i_permission_modify_power exists and i_client_needed_permission_modify_power exist at the same time.
    What does one do that the other doesn't do? Why do we have both?
    18,151
    1 says you can modify permissions the other one says you need at least a i_client_permission_modify_power with value X to modify client permissions.
    July 2016
    Unhappy (failed on i_client_needed_permission_modify_power)
    Hello.
    Before i started, sorry for my english.
    When i have Server Admin permissions modify power 75, and needed permissions modify power 75 i can't modify channels.
    Why?
    4,351
    Post full permission overview. Most likely missing Grant.
    November 2014
    Assigning groups (failed on i_client_needed_permission_modify_power)
    insufficient client permissions (failed on i_client_needed_permission_modify_power)
    Admin group has client permission modify power of 55
    The group I want to be able to assign has a needed assign power of 40.
    I have been trying to fix this group issue for days. I've searched the forums, google, and still no luck fixing this.
    First image is 'admin' group (not default server admin)
    Second image is the group the 'admin' group cannot assign to self or anyone.
    18,151
    Target user has a i_client_needed_permission_modify_power which is higher than executing user's current i_client_permission_modify_power.
    Check the permissions overview of that target and executing user (right click on that users -> Permissions). Not only the permissions of these one groups.
  1. Group Member Self Add/Remove Power
    By Draygo in forum Suggestions and Feedback
    Last Post: April 7th, 2016, 06:50 PM
  2. [Not possible] Restricting Member Add/Remove Power to only channel groups
    By CreepYx in forum Permission System
    Last Post: January 21st, 2016, 02:32 PM
  3. [Rejected] [Suggestion] to add flexibility to member add/member remove permissions.
    By Morthawt in forum Suggestions and Feedback
    Last Post: September 18th, 2014, 08:38 AM
  4. failed on i_client_needed_permission_modify_power
    By Ishban in forum Permission System
    Last Post: December 15th, 2013, 03:23 PM
  5. Group Member add power remove i_group_needed_member
    By Rogerdoger45 in forum Permission System
    Last Post: January 13th, 2013, 05:33 AM
