Results 1 to 8 of 8
    March 2015
    Mass Message Plugin?
    I am looking for a Mass Messaging plugin. Not sure if LUA Plugins are still able to be used with this new teamspeak if so no idea how to install them so any help here is appreciate. Thank you in advance.
    August 2013
    540
    Of course you can still use LUA scripts if you installed the LUA plugin from MyTeamspeak.
    Or you could wait for me to finish https://github.com/Bluscream/pyTSon_...on/__init__.py
    October 2015
    Germany, Bavaria
    140
    I have an SQ set written... Basically, you configure it via the UI and just run it.
    I have only tested it on Win8.1, no idea if it works on other OSes. Also features AFK handling, server-messaging, command to get admins notified, and things like !votekick and !voteban
    You can disable each module by just not starting it.
    Works via SQ though, and its Win-only afaik. So I don't know if it works...
    Download package
    On one package, you can basically set messages, an interval, and if they play randomly or in order. If that is what you want...
    Its also written in Python, but compiled to an exe.
    September 2005
    Germany / Dortmund
    1,376
    The copyright to https://github.com/nikdoof/python-ts3 (I guess) is missing in your package!
    October 2015
    Germany, Bavaria
    140
    I can really recommend nikdoof's TS3 SQ API, I am using that aswell for python. Its really easy to use and a great way to do that.
    And yes, the credits were missing.
    I did add it now though, thanks for reminding.
    August 2013
    540
    Quote Originally Posted by Thomas View Post
    I hope you know that you can be pretty annoying too :P
    October 2015
    Germany, Bavaria
    140
    Bluescream, is yours a plugin API, translated LUA API or ServerQuery API?
    August 2013
    540
    It's written in python and won't use any additional packages.
  1. Mass Move, Mass Poke - Superadmin privileges updated for TS 3.0.18+
    By kito2 in forum Client Plugins / Lua Scripts
    Last Post: February 4th, 2018, 12:55 AM
  2. Need good mass poke plugin..
    By Roisver in forum Client Plugins / Lua Scripts
    Last Post: June 29th, 2016, 08:43 PM
  3. Problem with Mass EH TS3 Tools Plugin
    Last Post: April 26th, 2016, 07:53 AM
  4. [Request] Plugin for mass poke?
    By wil32 in forum Client Plugins / Lua Scripts
    Last Post: November 23rd, 2015, 12:05 AM
  5. [Bug] Mass Refreshing Plugin leading to client crash
    By willy_sunny in forum Bug Reports [EN/DE]
    Last Post: September 23rd, 2010, 08:41 AM
