Results 1 to 4 of 4
    March 2017
    Sound gone when using Bluetooth headset
    Tried to use Bluetooth headset connected via A2DP.
    Everything works ok everywhere in system. Everything works ok when I test it in TeamSpeak settings ("Testing the playback sound system"). But after I connected to TS server, everyting gone: no UI notifications, no voice, no sound from any other app in system through this device. Mic seems to work (at least shows input levels).
    The problem dissapears only when I completely close the TS. Disconnecting from server also doesn't work. TS shows no error messages (as it does when I reconnect the device).
    I don't exactly know that the problem is in TS, but no one else kills sound as the TS.
    May be this is related to strange server settings: when I connect, the TS plays two UI notifications ("insufficient permissions" and something else) simultaneously. When I connect with BT headset, I didn't hear them also.
    This may be duplicate of http://forum.teamspeak.com/threads/1...le-mic-is-fine
    18,497
    Could you please give us some details about your current operation system and offer us a client log.
    What Default Formats can you select for your Bluetooth device under playback and recording?
    For Windows do following to find the available formats:
    1. Do a right-click on the Speaker iconwhich can be found in your Taskbar
    2. Select Playback/Recording devices
    3. Do a right-click on your BT device and select Properties
    4. Now select the Advanced tab
    March 2017
    The only supported format for playback is Stereo/16bit 44.1kHz. Selection is unavailable.
    The only supported format for recording is mono/16bit 8kHz. Selection is also unavailable.
    OS: Win8.1 x64
    Here are logs. I tried to restart a few times to somehow override the problem.
    August 2017
    Quote Originally Posted by [email protected] View Post
    OS: Win8.1 x64
    Bumping that post. I'm having the same issues. The weird thing is that TS was working well last 2 mounth with the same BT headsets and nothing changed...perhaps some windows 10 updates, but controlled hasn't changed the date as september 2016.
    Please enlightme...
  1. Replies: 12
    Last Post: July 26th, 2019, 10:58 PM
  2. Replies: 0
    Last Post: April 17th, 2016, 12:47 PM
  3. Windows: Bluetooth headset kills all sound
    By DumSkidderik in forum Windows
    Last Post: September 11th, 2014, 11:03 PM
  4. No sound with bluetooth headset
    By robertfriedland in forum Client Support
    Last Post: August 18th, 2010, 09:15 AM
