Results 31 to 45 of 49
  1. #31
    April 2017
    Quote Originally Posted by jluerken View Post
    Same here.
    Win10 Creators Update - TS 3.1.3 - GTX 980TI and latest NVidia drivers = TS does not start
    Win10 Creators Update - TS 3.1.3 - GTX 980TI and older NVidia drivers = TS does start
    +1
    But using --force-opengl-angle worked for me, though.
  2. #32
    April 2017
  3. #33
    April 2017
    Here as well. Win10 Creators, after nV driver update, TS doesn't start.
  4. #34
    January 2017
    From today i've noticed the same problem and no solution, have you find one?
  5. #35
    January 2017
    Hey bro seems thats a driver problem! http://forum.teamspeak.com/threads/1...-driver-381-65 only for the moment i fixed using the parameters passed from the devs, i hope this would help you!
  6. #36
    April 2017
    I can confirm, roll back your nV drivers. It works again for me.
  7. #37
    April 2017
    Cant start after update
    Quote Originally Posted by thorwe View Post
    How to parameters:
    Explorer to your TeamSpeak installation directory.
    Locate ts3client_win(32/64).exe
    Right click -> Create shortcut.
    Optional: rename shortcut to e.g. TS - Angle
    Right click the shortcut -> Properties.
    In the target field you can then add the parameter.
    Note that if there're quotes, only the path should remain in quotes, leave the parameter outside.
    Optional: Right click shortcut, add to task bar / start and such.
    Attempted the above mentioned parameters. They did not work.
    adding --force-opengl-angle resulted in
    "The name 'F:\TeamSpeak3\ts3client_win64.exe--force-opengl-angle' specified in the Target box is not valid. Make sure the path and file name are correct. "
  8. #38
    April 2017
    Quote Originally Posted by TeknoPanda View Post
    where i can use parameters?
    http://www.digitalcitizen.life/pin-s...-or-start-menu
    By the way the same problem for me:
    GTX 1080 FTW ACX 3.0
    Using the parameters work for me
  9. #39
    April 2017
    Having the same problem after the updates. I have tried the above mentioned parameters, but they don't work for me. Maybe I'm doing it wrong but I get a error message when I try to apply the suggested parameter.
  10. #40
    April 2017
    Teamspeak 3 won't open
    I have the same problem, I try to start the program. It doesn't even open on the screen or toolbar area. It's starts in the process area of the task manager for a second then goes away. I've tried running as administrator and compatibility mode Vista sp 2. Same result. Windows 7
  11. #41
    18,151
    1. Do a right click on your TeamSpeak shortcut.
    2. Select Properties
    3. Open the tab Shortcut
    4. Add " --force-opengl-angle" or " --force-opengl-soft" (without the " but with a space before --) to Target line
    5. Press OK or Apply
  12. #42
    April 2017
    Thanks!
    LOL, I was doing all that and getting furious for the errors.....then I read it needed a space.....that space is brutal....
  13. #43
    18,151
    Quote Originally Posted by tog148 View Post
    That's normal for start parameters to split them with a space.
  14. #44
    April 2017
    nVidia Driver fixed the problem for me
    Had the same problem, re-installing teamspeak didnt work. Changed nVidia Driver from 381.65 to 378.92, now it works.
    Last edited by dante696; April 11th, 2017 at 11:20 AM. Reason: moved to right thread
  15. #45
    18,151
    We will release client 3.1.4 today (or tomorrow) to fix this issue.
    That client allows you to use the latest Nvidia driver and TeamSpeak at the same time.
    Stay tuned and check Announcements Section for news
    or visit teamspeak.com/downloads tomorrow to grab client 3.1.4 directly.
  1. Issue running lua scripts with the lastest update (3.1.2)
    By lord edd in forum Client Plugins / Lua Scripts
    Last Post: March 29th, 2017, 01:47 AM
  2. Replies: 3
    Last Post: January 19th, 2010, 08:27 AM
