Results 1 to 2 of 2
    April 2017
    9
    Transmission Issue
    I don't know why, but for whatever reason, I can only transmit via continuous transmission and you can imagine why that would be a problem, especially being the leader of an Arma 3 milsim unit. I recently purchased a new headset so that this issue that was had with my previous headset could be dealt with, so I presume that it's not my headset as it's the same situation with both. I'd suspect that the cause of this error is the inability for my mic to activate when a key is pressed or a voice is sounded. There's this red line across the voice measurement or test area whenever I attempt to speak in either Push-to-Talk or Automatic Voice Detection, and I presume that that means that there's something wrong with my mic (as seen in the 'attached images' below. A quick solution to my problem would be much appreciated and I thank you for your time in reading my post in advance.
    April 2017
    9
    Am I not going to get a response??
  1. Only able to use Continuous Transmission
    By Dalligan in forum Client Support
    Last Post: August 3rd, 2016, 04:25 PM
  2. One Ear Transmission
    By PenguinScythe in forum General Questions
    Last Post: October 27th, 2013, 01:14 PM
  3. Transmission not working.
    By Zephyrcakes in forum Client Support
    Last Post: March 8th, 2011, 10:27 AM
  4. only able to use continuous transmission
    By Sprite in forum Windows
    Last Post: November 13th, 2010, 03:50 PM
