Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    April 2017
    14
    Same thing happens to me, they don't seem to be able to help...
  2. #17
    6,078
    Quote Originally Posted by Coutie View Post
    Simply because there is no information provided for anyone to possibly say anything meaningful.
    Please check the log files and post the complete log file of the client here.
    You can find the logs in %AppData%\TS3Client\logs or in InstallDir\config\logs where "InstallDir" is the path you installed the client in to. There should also be a folder called crashdumps. Please attach the last crashdump file as well if there are any.
  3. #18
    April 2017
    14
    Hmm
    http://forum.teamspeak.com/threads/1...ash-on-startup
  4. #19
    6,078
    merged these threads. We'll take a look again at those dumps.
    In the meantime you can try and see if the current beta version works:
    Tools -> Options -> Application. Select Update Channel: Beta. Ok
    Help -> Check for Updates -> Yes
  5. #20
    April 2017
    14
    Well, it crashes on startup, so there's no way to do it.
  6. #21
    June 2017
    Africa - Egypt - Alexandria
    Solved Proplem resolved
    proplem resolved there was an application incompitable proplem
    fixing steps
    1- click right on Teamspeak3's shortcut -> choose 'Troubleshoot compatibility'
    2- Wait for Application compatibility checks
    3- choose 'Try recommended settings'
    4- choose 'start the program' to test it after fixs
    5- enjoy the Best Application (Teamspeak3)
    Note: iam using Windows 7 Pro x86 bit
  7. #22
    6,078
    Ah yeah true. You can use the setup instead.
  8. #23
    April 2017
    14
    Program doesn't start. It appears on task manager for a second, then disappears.
  9. #24
    May 2016
    Idar-Oberstein
    163
    Hi Cutie,
    sorry for the delay.
    First, please backup your settings (safety first).
    They can be found, depending on your choice during installation in eiter %APPDATA%\TS3Client (just paste into an explorer path, it'll go to C:\Users\your_username etc.) or in [ApplicationInstallDir]\config.
    Then, you can download the beta 3.1.5 client installer here and simply install it over the the current stable, or uninstall the current one first - whatever you prefer.
    Now, that crash of yours is unfortunately quite deep in the code, meaning the beta1 hasn't fixed the issue yet - but it should exit with an error code instead (somewhat like Critical encryption error: Failed to init: [error nummer]), shown via a message box and in your client log.
    To find out what really causes this problem and hopefully fix it, we'd need this error code.
  10. #25
    April 2017
    14
    The program doesn't start at all, and it doesn't create any files in that directory. The stable build will, but the beta just doesn't do anything.
  1. TS3 crash on startup since 3.0.17
    By JIP0815 in forum Windows
    Last Post: October 22nd, 2015, 08:46 AM
  2. Crash on startup
    By PrivateSniper in forum Windows
    Last Post: February 20th, 2012, 12:10 PM
  3. Complete crash on startup
    By Phage18 in forum Windows
    Last Post: May 15th, 2011, 02:27 AM
  4. [Solved] Crash on Startup
    By Wismerhill in forum Bug Reports [EN/DE]
    Last Post: November 3rd, 2010, 02:36 PM
  5. CLient Crash upon Startup
    By matt4tay in forum Bug Reports [EN/DE]
    Last Post: August 3rd, 2010, 06:25 AM
