Results 1 to 3 of 3
    May 2017
    Minimalist interface with anchored buttons
    I try to create a minimalist interface of teamspeak with only the possiblity to connect or disconnect (no custom server or nickname, only IN and OUT).
Name:	Unity (64bit) - Client_Example.png
    There is only 2 buttons: connect and disconnect.
    That's the "connect" button (showing that actually it's disconnected)
    And that's the "disconnect" button (showing that it's actually connected)
    I managed to do that with the example project, but i can't anchor those buttons for them to stay on top left of the screen when we change the resolution.
    Like you can see here.
    The structure in the Hierarchy pannel don't allow me to move the buttons for being direct childs of the canvas (wich allow me then to use anchors on the buttons) because the script don't work anymore...
    Could you advise me on how to add anchors to those buttons without the script to freak out?
    January 2016
    Munich / Bavaria
    16
    Hi Nanodatron,
    Can you tell me exactly what you do and what happen?
    And I need the error messages.
    In general about your resolution problem, you need to take a look at the unity documentations.
    https://docs.unity3d.com/Manual/HOWT...esolution.html
    Regards
    Alex G.
    May 2017
    Hi Alex_G
    I tried my best to explain in detail the problem earlier. I finally found a way to make it work. If anybody else have the same problem and recognise it in my description, here is a resume of how it can work:
    - Create two new canvas at the root of the Hierarchy. One for the button "connection" and one for the button "connected"
    - Very important: Set the tag of the new canvas "connection_pannel" to "con_01" and "connected_pannel" to "con_02"
    - Next, select the game object: "TeamSpeakClientExample" and assign the 2 parameters "Connection_Pannel" and "Connected_Pannel" to our two new canvas (drag-drop the game objects on the field).
    - Then select all the childrens inside the old "connection_pannel" and "connected_pannel", and move them as childrens of the new canvas.
    - You can supress the 2 unused old ones
    - NOW you can assign an anchor to each buttons, and not worry about what will happend when the resolution of screen will change.
    I have another issue now, first i start to see on my side, and if i can't manage, i will create a new topic. Thanks
  1. [OFFline] Minimalist Text to Speech
    By joelpt in forum Client Plugins / Lua Scripts
    Last Post: July 14th, 2016, 03:59 AM
