Results 1 to 10 of 10
    June 2017
    Scaling is broken with a second monitor
    Under Windows 10
    Looks like this (screenshot):
    As you can see the chat name shold be "Ragonn's Treff" but it doesn't get fully displayed. Same for "Eingangshalle".
    18,513
    This can happen when
    - you use or used more than 1 monitor on Nvidia graphic card. A reboot helps.
    - you use more than 1 monitor and have a different scaling active. Start the client on target monitor and do not move it to the other one.
    June 2017
    thanks, second case was the reason
    December 2015
    273
    Shouldn't that be easily fixable? With a resize call after a monitor-number switch of the QT application?
    Or does different scaling mean something else than 2 monitors with different resolutions.
    18,513
    I can't say for sure that we can or can't fix or add a workaround.
    Point 2 is under evaluation for our developers and i will add that suggestion into our ticket.
    December 2015
    273
    Dunno if helpful or not..
    http://doc.qt.io/qt-5/qdesktopwidget.html#screenNumber
    https://stackoverflow.com/questions/...cross-monitors
    August 2018
    Scaling on high resolution screens
    I can't find any posts regarding this using the search function, thus decided to create a new thread.
    I have both a 4K and a 1440p screen, which are set to different DPI Scaling settings in Windows.
    However, as a result whenever I move teamspeak from one screen to another the scaling gets all messed, making the text and icons way too big. I do not see a setting to disable or alter (text)scaling.
    Am I not seeing it or is this not yet support?
    Are there plans to support or have better support for DPI scaling the future?
    Screenshots below,
    Thank you!
    September 2018
    I have the same problem with a 4k and a 1680x1050 monitor.
    My scaling on the 4k monitor is 200% and on the other 100%.
    When TeamSpeak is on the 4k monitor, everything is normally scaled, but on the other screen everything is messed up.
    4k: https://i.imgur.com/mMxviZ7.png
    1680x1050: https://i.imgur.com/rwObFE4.png
    Would be nice if someday it would be fixed...
    January 2017
    Switzerland
    461
    Does it looks the same if you turn off your designs/icon-packs? (set back to default)
    September 2018
    Quote Originally Posted by MCGamingDE View Post
    Yes, it looks the same.
  1. [no bug?] 2nd monitor
    By tolle wurst in forum Bug Reports [EN/DE]
    Last Post: February 21st, 2011, 06:22 PM
