Page 5 of 6 FirstFirst ... 3456 LastLast
Results 61 to 75 of 81
  1. #61
    November 2008
    germany
    Teamspeak keeps crashing instantly on startup
    Hey guys,
    just reinstalled windows on my laptop after swapping the hard drive and tried to get teamspeak running.
    It always crashes when i start it up. I tried older versions of teamspeak and i tried deleting the appdata folder. Nothing seems to help. Fresh Windows 7 ultimate installation, fresh actual teamspeak client. No plugin bullshittery or anything else. TS is 100% vanilla.
    Also added the dump
    2018-10-02 19:42:18.512260|INFO | | |TeamSpeak 3 Client 3.2.2 (2018-09-17 10:01:05)
    2018-10-02 19:42:18.512260|INFO | | |SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    2018-10-02 19:42:18.528261|DEBUG |Direct Sound | |setting timer resolution to 1ms -
    2018-10-02 19:42:20.592379|INFO |ClientUI | |Unable to create an Open GL context.
    2018-10-02 19:42:20.593379|ERROR |RevocationListCache| |Failed to import revocation list from cache
    2018-10-02 19:42:20.647382|INFO |Addons | |Checking for addon updates...
    2018-10-02 19:42:20.659382|INFO |Plugins | |Loading plugin: gamepad_joystick_win64.dll
    2018-10-02 19:42:20.762388|INFO |Gamepad Plugin| |Found client raw input wnd proc
    2018-10-02 19:42:20.762388|INFO |Gamepad Plugin| |Cleared device list
    2018-10-02 19:42:20.764388|INFO |Plugins | |Loading plugin: lua_plugin.dll
    2018-10-02 19:42:20.959400|INFO |Plugins | |Api version is not compatible for plugin: C:\Program Files\TeamSpeak 3 Client\plugins\lua_plugin.dll
    2018-10-02 19:42:20.963400|INFO |Plugins | |Loading plugin: ts3g15.dll
    2018-10-02 19:42:20.964400|INFO |Plugins | |Api version is not compatible for plugin: C:\Program Files\TeamSpeak 3 Client\plugins\ts3g15.dll
    2018-10-02 19:42:20.964400|INFO |Plugins | |Loading plugin: appscanner_plugin.dll
    2018-10-02 19:42:20.972400|INFO |Plugins | |Api version is not compatible for plugin: C:\Program Files\TeamSpeak 3 Client\plugins\appscanner_plugin.dll
    2018-10-02 19:42:20.974400|INFO |Plugins | |Loading plugin: clientquery_plugin_win64.dll
    2018-10-02 19:42:20.978401|INFO |Query | |listening on 127.0.0.1:25639
    2018-10-02 19:42:20.979401|INFO |Plugins | |Loading plugin: test_plugin.dll
    2018-10-02 19:42:20.980401|INFO |Plugins | |Api version is not compatible for plugin: C:\Program Files\TeamSpeak 3 Client\plugins\test_plugin.dll
    2018-10-02 19:42:20.980401|INFO |Plugins | |Loading plugin: teamspeak_control_plugin_win64.dll
    2018-10-02 19:42:20.984401|INFO |ControlPlugin | |Control Plugin started, accepting connections
    2018-10-02 19:42:20.984401|INFO | | |*** Time [PLUGINS]: 325
    2018-10-02 19:42:21.010402|INFO | | |successfully downloaded revocation list for accounting
    2018-10-02 19:42:21.011403|INFO | | |successfully downloaded revocation list for myteamspeak id
    2018-10-02 19:42:21.065406|INFO |Addon | |Addon up to date.
    2018-10-02 19:42:21.128409|INFO |SyncImpl | |Creating default config in local storage
    2018-10-02 19:42:21.334421|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    2018-10-02 19:42:21.334421|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    2018-10-02 19:42:21.402425|INFO | | |*** Time [SERVERVIEWMANAGER]: 246
    2018-10-02 19:42:21.484430|INFO | | |*** Time [MAINWINDOW]: 2979
    2018-10-02 19:42:21.484430|INFO | | |*** Time [INIT]: 2979
    2018-10-02 19:42:21.485430|DEVELOP |ClientUI | |Notifications init: Soundpack path: C:/Program Files/TeamSpeak 3 Client/sound\default
    2018-10-02 19:42:21.492430|INFO |ClientUI | |Qt version: 5.6.2
    2018-10-02 19:42:21.492430|INFO |ClientUI | |Using configuration location: C:\Users\BadDoggo\AppData\Roaming\TS3Client\settin gs.db
    2018-10-02 19:42:22.675498|INFO |Bookmarks | |Collecting autoconnect bookmarks
    2018-10-02 19:42:22.678498|INFO |ClientUI | |Last update check was: Di Okt 2 21:32:10 2018
    2018-10-02 19:42:24.882624| |KeyBindings | |Default monitoring disabled
    I would appreciate help.
  2. #62
    November 2008
    germany
    --force-opengl-soft seems to help me in this case
  3. #63
    August 2018
    France
    Post TeamSpeak 3.2.2 [Stable] Crash
    Hello guys. So, when I go to options (ALT+P) my TeamSpeak Client just crash without reason.
    Can someone help me?
    Attached Files Attached Files
  4. #64
    November 2018
    delete post + attached files thanks
    Hello, good evening, I have problems with the installation and opening of ts on my Windows Ultimate 7. I state that I have updated all the updated drivers and the update of Windows, it seems that it has compatibility problems, once the procedure is done correctly of installation, at the start, after 2 seconds it stops and gives me a ts .. As per instructions I disabled the plugins with the mode -safemode, I set parameters like - force-opengl-desktop and -force-openlg- soft, but crasha the same In attachment I try to attach all the details of the crash
    P.s.
    it is impossible to attach the txt dxdiag file to this forum. I try to copy the main features
    http://prntscr.com/lf3uun
    http://prntscr.com/lf3v6w
    http://prntscr.com/lf3vh7
    http://prntscr.com/lf3vun
  5. #65
    17,942
    Re from one of the duplicate posts that i deleted instead of that one .....
    The attached zip file is corrupt but not needed here.
    From the attached log and dxdiag i see 2 problems.
    Your sound card driver and graphics card driver are not maintained since 2009 and 2011.
    The graphics card does not support a feature we need for the client and zhis is why it does crash..
    The error "Unable to create an Open GL context" appears when your graphics card or driver can't handle required OpenGL properly.
    This can happen on really old devices or integrated graphics card.
    • Make sure your drivers are up to date (includes your graphics card driver was maintained last months or at least last 2 years).
    • Install latest Windows 7, 8.1, 10 Updates (and Win 7 service pack).
    • Try to run the client with start parameter --force-opengl-soft as a workaround.
      But we can't promise that this will fix your issue.
  6. #66
    November 2018
    Teamspeak 3 Crash on startup
    Today my teamspeak decided to crash on startup.
  7. #67
    November 2018
    New Install Crashes on Startup
    I installed the latest teamspeak 3 client and my Toshiba netbook. It installed with no issues but after accepting the EULA it crashes. Re-installing has not worked and I attached the dump file. This is a first time install so it never worked before and this netbook has windows 7 starter edition. Also all windows updates are current including .net framework.
  8. #68
    January 2017
    11
    [CRASH] TeamSpeak Error
    Hello everyone!
    INFORMATION:
    What client version is running: TeamSpeak3-Client-win64-3.2.3
    Offer us a Client log: https://pastebin.com/Kw3avi1k
    What operating system is working: Windows 7 Home Premium 64 Bits
    All important OS updates are installed: Yes
    The latest drivers (sound card, network card, USB devices, graphics card, etc.) are installed: Yes
    This worked before: The client version 3.1.1.1 works without problems on my computer, but after I install the latest version, when I open TeamSpeak it crashes automatically.
    Failure reports crashdumps DxDiag: https://pastebin.com/F5MgDf2g
    Please help me!
  9. #69
    January 2019
    Crash on startup
    im not good at englinsh this i want to say first
    Hi i have a problem with TS3,he crash at startup, i have Windows 7 64 bit, i tried to reinstall windows 7 so many times, same result, and i dont know how o resolve this problem, anyone can say how to resolve this problem, please help me
    CRASH DUMP FROM APPDATA
    https://www100.zippyshare.com/v/fKLq6KUt/file.html
    https://www100.zippyshare.com/v/CMjsTs9R/file.html
    https://www100.zippyshare.com/v/ERxtlXsM/file.html
    https://www100.zippyshare.com/v/EB8kFlNI/file.html
  10. #70
    January 2019
    error, TeamSpeak
    Hi, I want to notify in advance that I will use Google translator. I installed the latest version of TeamSpeak. TeamSpeak crashed and reported an error.
    I can provide a dump file and system data.
  11. #71
    January 2019
    Teamspeak 3 Crash On Startup
    Hey All, i install the teamspeak 3, then opens, I accept the agreement, and when that window goes away and I'm left with the client it just crashes, i have windows 7, 1Gb
  12. #72
    January 2019
    Crashes
    Hi, my name is Hovhanna.
    I want to say in advance that I will use Google translator.
    Team Speak 3 client version 3.2.3.0 doesn't work for me. When I launch Team Speak, I am asked to accept the terms of the agreement, after which the program crashes.
    The Visual Office 2015 and .net framework 4.6 are installed on the computer
    Above I provide the necessary files to find the cause of the failure.
  13. #73
    June 2018
    Poland
    83
    Update ur graphic drivers first and make sure u got latest updates also to ur os.
  14. #74
    January 2019
    The drivers for my computer have been updated, I recently reinstalled Windows 7 and used the Driver Booster 6.2.1.263 service.
  15. #75
    January 2019
    Client crahes everytime on startup
    Hey guys,
    I ran into a problem with my TeamSpeak 3 client. Everytime if I want to start it, it instantly crashes.
    I don't get anything from the logfiles, but hopefully one of you could help me out here.
    I installed last C++ Redistributable 2017 and the latest client.
    The log file is attached.
  1. [Evaluation] Client still can open ServerQuery user connection info context menu
    By KIDINK^ in forum Bug Reports [EN/DE]
    Last Post: April 1st, 2016, 10:55 PM
  2. Unable to open a 2nd client
    By Clockbender in forum Windows
    Last Post: July 9th, 2015, 07:54 PM
  3. Replies: 0
    Last Post: April 16th, 2015, 12:09 AM
  4. [Resolved] Unable to use mysql data base... unable to create tables
    By 3dhomejoe in forum Windows
    Last Post: October 3rd, 2011, 04:28 PM
  5. [Suggestion] Tree Client Context Menu, "Move Client to own Channel"
    By kokuei in forum Suggestions and Feedback
    Last Post: September 24th, 2011, 10:44 PM
