Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    September 2017
    I have the same problem, my ts3 client crashes when I start it.
    I download the lasted version, the one is on site, and my mac is full updated. So I dont know why I have this problem.
    If you can help me, I apreciate. Thanks
  2. #17
    November 2017
    [BUG] Mac client crashes on startup on Case-sensitive filesystems
    Within Mac Application directories, the 'Resources' directory always exists with initial-caps.
    However, if TeamSpeak is installed onto a Case-sensitive filesystem, then it crashes on startup with 100% reproducibility because it is looking for data in a (non-existant) 'resources' directory:
    $ ./MacOS/ts3client_mac
    Crashdump ENABLED,  directory is: /Users/Stuart/Library/Application Support/TeamSpeak 3/crashdumps
    DUMP defined! Dumpdir is: /Users/Stuart/Library/Application Support/TeamSpeak 3/crashdumps
    2017-11-22 23:26:11.267305|INFO    |              |   |TeamSpeak 3 Client 3.1.4.2 (2017-06-28 10:01:41)
    2017-11-22 23:26:11.267619|INFO    |              |   |SystemInformation: Darwin 17.2.0 Darwin Kernel Version 17.2.0: Fri Sep 29 18:27:05 PDT 2017; root:xnu-4570.20.62~3/RELEASE_X86_64 x86_64 Binary: 64bit
    2017-11-22 23:26:11.320648|INFO    |ClientUI      |   |OpenGL Info: LibGL, Vendor: ATI Technologies Inc., Renderer: AMD Radeon HD - FirePro D700 OpenGL Engine, Version: 2.1 ATI-1.58.32
    2017-11-22 23:26:11.340351|INFO    |Addons        |   |Checking for addon updates...
    2017-11-22 23:26:11.809835|INFO    |SyncImpl      |   |Creating default config in local storage
    2017-11-22 23:26:11.988701|INFO    |              |   |*** Time [MAINWINDOW]: 520
    2017-11-22 23:26:11.988799|INFO    |              |   |*** Time [INIT]: 520
    2017-11-22 23:26:11.989160|DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /Users/Stuart/Applications/TeamSpeak 3 Client.app/Contents/SharedSupport/sound/default
    2017-11-22 23:26:13.864771|INFO    |ClientUI      |   |Qt version: 5.6.1
    2017-11-22 23:26:13.864874|INFO    |ClientUI      |   |Using configuration location: /Users/Stuart/Library/Application Support/TeamSpeak 3/settings.db
    2017-11-22 23:26:14.016859|INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
    2017-11-22 23:26:14.017465|INFO    |ClientUI      |   |Last update check was: Wed Nov 22 23:22:43 2017
    Qt WebEngine ICU data not found at /Users/Stuart/Applications/TeamSpeak 3 Client.app/Contents/resources. Trying parent directory...
    Qt WebEngine ICU data not found at /Users/Stuart/Applications/TeamSpeak 3 Client.app/Contents. Trying application directory...
    Qt WebEngine ICU data not found at /Users/Stuart/Applications/TeamSpeak 3 Client.app/Contents/MacOS. Trying fallback directory... The application MAY NOT work.
    Installed Qt WebEngine locales directory not found at location /Users/Stuart/Applications/TeamSpeak 3 Client.app/Contents/translations/qtwebengine_locales. Trying application directory...
    Qt WebEngine locales directory not found at location /Users/Stuart/Applications/TeamSpeak 3 Client.app/Contents/MacOS/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
    [1122/232614:FATAL:content_main_runner.cc(735)] Check failed: base::i18n::InitializeICU().
    Starting Error Reporter: /var/folders/z7/t20rykbd5x9d0w80j328zt_00000gn/T/error_report.sh
    (... please note that this same error also occurs with version 3.1.5 and 3.1.6, but I was stepping backwards through recent releases to find the last working version. There have been earlier (3.1.x?) releases not affected by this bug, as I was running one prior to upgrading!)
    P.S. If TeamSpeak is upgraded in-place rather than by manually downloading the new version, the application's signature is reported to no longer be valid by v4.x of the LittleSnitch firewall.
  3. #18
    November 2017
    same here on High Sierra in case sensitive FS
    the symlink workground works. the problem is want to found 'resources' directory instead of 'Resources' like the app provide
    └───╼  ./ts3client_mac
    Crashdump ENABLED,  directory is: /Volumes/Home/Hakintoch/Library/Application Support/TeamSpeak 3/crashdumps
    DUMP defined! Dumpdir is: /Volumes/Home/Hakintoch/Library/Application Support/TeamSpeak 3/crashdumps
    2017-11-26 16:37:24.239690|INFO    |              |   |TeamSpeak 3 Client 3.1.6 (2017-08-16 08:59:43)
    2017-11-26 16:37:24.240052|INFO    |              |   |SystemInformation: Darwin 17.2.0 Darwin Kernel Version 17.2.0: Fri Sep 29 18:27:05 PDT 2017; root:xnu-4570.20.62~3/RELEASE_X86_64 x86_64 Binary: 64bit
    2017-11-26 16:37:24.344828|INFO    |ClientUI      |   |OpenGL Info: LibGL, Vendor: NVIDIA Corporation, Renderer: NVIDIA GeForce GTX 770 OpenGL Engine, Version: 2.1 NVIDIA-10.27.6 378.10.10.10.20.107
    2017-11-26 16:37:24.388481|INFO    |Addons        |   |Checking for addon updates...
    2017-11-26 16:37:24.391997|INFO    |Plugins       |   |Loading plugin: libclientquery_plugin_mac.dylib
    2017-11-26 16:37:24.429436|INFO    |Query         |   |listening on 127.0.0.1:25639
    2017-11-26 16:37:25.492782|INFO    |SyncImpl      |   |Creating default config in local storage
    ClientQueryPlugin: currentServerConnectionChanged 1 (0)
    2017-11-26 16:37:25.706085|INFO    |              |   |*** Time [MAINWINDOW]: 1202
    2017-11-26 16:37:25.706202|INFO    |              |   |*** Time [INIT]: 1203
    2017-11-26 16:37:25.706703|DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /Applications/TeamSpeak 3 Client.app/Contents/SharedSupport/sound/default
    2017-11-26 16:37:26.268859|INFO    |ClientUI      |   |Qt version: 5.6.2
    2017-11-26 16:37:26.268977|INFO    |ClientUI      |   |Using configuration location: /Volumes/Home/Hakintoch/Library/Application Support/TeamSpeak 3/settings.db
    2017-11-26 16:37:26.466188|INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
    2017-11-26 16:37:26.467508|INFO    |ClientUI      |   |Last update check was: dom nov 26 16:36:02 2017
    Qt WebEngine ICU data not found at /Applications/TeamSpeak 3 Client.app/Contents/resources. Trying parent directory...
    Qt WebEngine ICU data not found at /Applications/TeamSpeak 3 Client.app/Contents. Trying application directory...
    Qt WebEngine ICU data not found at /Applications/TeamSpeak 3 Client.app/Contents/MacOS. Trying fallback directory... The application MAY NOT work.
    Installed Qt WebEngine locales directory not found at location /Applications/TeamSpeak 3 Client.app/Contents/translations/qtwebengine_locales. Trying application directory...
    Qt WebEngine locales directory not found at location /Applications/TeamSpeak 3 Client.app/Contents/MacOS/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
    [1126/173726:FATAL:content_main_runner.cc(735)] Check failed: base::i18n::InitializeICU().
    Starting Error Reporter: /var/folders/xg/1v6_p38956l315rdkt_s1b340000gn/T/error_report.sh
  4. #19
    November 2017
    seems fixed in 3.7.0
  5. #20
    18,513
    There is no fix yet in client 3.1.7
  6. #21
    November 2017
    nope, is not fixed. broken again when open the preferences:
  7. #22
    August 2013
    541
    Hmmm why do you consider posting on a forum if you don't read the answers?
    Last edited by dante696; January 23rd, 2018 at 07:26 PM. Reason: fixed the giant in your Quote.
  8. #23
    18,513
    Client 3.1.8 will fix that issue and allows user to run the client on case sensitive system.
  9. #24
    June 2016
    Serbia
    108
    When will Client 3.1.8 be released?
  10. #25
    18,513
    A beta client will be released today.
    The stable a few days after beta when there is nothing to fix afterwards.
  11. #26
    June 2015
    41
    Thanks dante, I will check asap if this fixed my issue. I was to lazy to reinstall the OS again with case-insensetive filesystem
  12. #27
    November 2017
    yep. now working (include preferences)
    tnx
    @Dorde
  1. [Resolved] External File System for TeamSpeak
    By Ronin Design in forum General Questions
    Last Post: September 24th, 2014, 11:43 AM
  2. Replies: 0
    Last Post: September 4th, 2011, 12:41 AM
  3. Client instantly disconnects
    By cbshea in forum Windows
    Last Post: July 3rd, 2011, 03:34 PM
  4. TeamSpeak 3 Crashes Entire System
    By NightMayor in forum Linux
    Last Post: February 22nd, 2010, 12:25 PM
