Results 1 to 11 of 11
    June 2014
    TeamSpeak 3 SRV records problem. Two server
    I have problem with my TS3 SRV records. I have tw oservers
    A on 9987
    B on 9988
    I set SRV record for B server like this "ts.xxx.com" t ofoward B server. When i try it all server foward to 9988 (include A server) and when i delete record SRV about ts.xxx.com all time adress ts.xxx.com or xxx.com:9988/xxx.com:9987 foward me to server B. How i can repeir it? To xxx.com foward 9987 to A server and xxx.com:9988 foward B server.
    4,367
    That can be done with SRV TSDNS only. SRV TS3 cannot do thisas it will always override the port. Point SRV TSDNS to your TSDNS server and set up a rule with $PORT as the port.
    December 2004
    RF
    3,008
    You understand what he's talking about? I barely make any sense of it, all I've got is that he have two vservers running, one on port 9987 and one on port 9988.
    The rest is a mystery.
    4,367
    I'm not entirely sure either. I think we wants to maintain ports but wants to host website and server on different machines. So he needs SRV TSDNS.
    April 2011
    1,266
    Why does he need SRV TSDNS? "Normal" SRV for voice should work just fine.
    4,367
    How does one maintain ports with SRV TS3?
    Solution: One can't.
    February 2012
    577
    Is it so difficult to create one SRV record for each TS server?
    One A record for the physical machine where the TS server is running on:
    machine.example.org 3600 A 111.222.333.444
    and one SRV record for each virtual server running on the above physical machine:
    _ts3._udp.ts1.example.org 3600 SRV 10 5 9987 machine.example.org.
    _ts3._udp.ts2.example.org 3600 SRV 10 5 9988 machine.example.org.
    _ts3._udp.ts3.example.org 3600 SRV 10 5 9989 machine.example.org.
    _ts3._udp.ts4.example.org 3600 SRV 10 5 9989 machine.example.org.
    _ts3._udp.ts5.example.org 3600 SRV 10 5 9990 machine.example.org.
    Accessible by users with ts1.example.org, ts2.example.org, ts3.example.org etc.
    4,367
    Quote Originally Posted by Schlumpi View Post
    For legacy, yes.
    December 2004
    RF
    3,008
    What do you mean by "legacy" ?
    4,367
    I have all my people connect to their servers via
    domain.com:1234
    domain.com:2345
    Now I want to host the website domain.com on a different server. Then I have to use SRV TSDNS so people can still connect.
    December 2004
    RF
    3,008
    You'll need to fix your broken setup sooner or later.
  1. Problem with SRV Records
    By Scrubs in forum Server Support
    Last Post: January 29th, 2017, 04:08 PM
  2. problem with srv records.
    By belmeg in forum Windows
    Last Post: April 25th, 2016, 05:24 PM
  3. [Suggestion] Server Details add 7 records.
    By hunterpl in forum Suggestions and Feedback
    Last Post: February 20th, 2012, 04:00 PM
  4. How do you delete user id records from the server
    By AgentExeider in forum Server Support
    Last Post: October 18th, 2010, 08:25 PM
