Results 1 to 5 of 5
    October 2017
    Wireless XBOX 360 controller conflicting with TS3
    Hello, as people that own a wireless 360 controller for the PC know, after a certain amount of time (10 minutes I believe) of inactivity, the controller will turn off (Also, if you take out the batteries). My problem is that when It turns off and Teamspeak 3 is open, when I turn on the controller I get no notification from Windows that I connected a device and also my controller does not work. Help please
    May 2010
    Charlotte, NC. USA
    9
    The FIX: and a problem that needs to be addressed.
    Go to options, settings, add ons.
    Gamepad and JoyStick Hotkey Support.
    UNINSTALL IT.
    December 2017
    Teamspeak 3 / Microsoft Xbox 360 Wireless controller
    Having Teamspeak open stops my Xbox 360 wireless controller working in Windows 10 when the controller wakes from sleep. Closing Teamspeak returns the xbox controller to operation. In every instance, the controller does reconnect with the USB wireless receiver, just not functional. I have 2 identical controllers and USB receivers, both exhibit the same issue.
    Previously I had this issue and was advised by Microsoft support to install the Xbox 360 accessories pack for Windows 7. This seemed to resolve the issue for a couple months but now it's back. At the time I had not made any connection with Teamspeak being involved in the issue.
    Where do I start with this please ?
    December 2017
    Prevents controller use.
    I have confirmed that TS3 causes connection issues for my XBOX 360 controller. When shutting off my controller I am unable to get the controller to reconnect unless I first shut down TS3.
    The controller is able to initially connect with no problems, upon first connect.
    Any additional disconnect and then reconnects require shutting down TS3.
    I have replicated this connection issue multiple times by turning off my controller and then attempting to reconnect it. Upon no connection, I shut down TS3, and after a few seconds the controller automatically connects (windows makes a connection sound) allowing me to use the controller normally. I then have to relaunch TS3 for use. I am unsure if it is causing issues anywhere else, nor do I understand how this is happening.
    December 2017
    Thumbs up FIX: xbox controller not working after sleep
    Quote Originally Posted by DigitalFlow View Post
    UNINSTALL IT.
    Thanks DigitalFlow that is precisely the issue and resolution. Disabling it also seems to work but I have removed it all the same as you suggest.
    Cheers,
    A11an
  1. [Resolved] Xbox One Controller for P2T issue (after Anniversary Update)
    By TehHarbs in forum Windows
    Last Post: July 7th, 2017, 10:37 AM
  2. xbox one controller not recognized
    By RobbieB in forum Windows
    Last Post: June 16th, 2016, 10:59 AM
  3. [Release] XBOX 360 Controller buttons Push To Talk
    By Mr_KoKa in forum Client Plugins / Lua Scripts
    Last Post: April 14th, 2015, 07:11 PM
  4. Replies: 0
    Last Post: December 10th, 2011, 05:21 AM
