Results 1 to 15 of 15
    September 2017
    47
    Problems after Update 3.1.7
    With the latest 3.1.7 update of teampeak for android, I found problems:
    1) When I connect to a server, and then I leave the server, the application does not close, but remains active and says that it is still connected to the server, and to exit I have to finish the application...
    2) When I connect to a server, and if while you have change ideas, and touch on "Cancel", the application completely crashes, crashes completely, and the Android menu turns black, and to close the Teamspeak app, I have to go into settings -> Applications -> Application Information, and end it from them.
    3) Almost always appears a page with "license agreement" with reject keys etc., and by mistake touch reject and every time I throw myself out of the server, should not appear... and very annoying... please fix.
    Please let us get out a new update that solves these problems, you can't use it like this
    Thank you
    September 2017
    47
    Teamspeak 3.1.8 Android
    I would like to know, will it also be available on android teamspeak 3.1.8? when?
    There are so many problems that need to be solved at version 3.1.7.
    Thanks
    18,144
    There is no release date and no relation to the pc client release.
    Quote Originally Posted by Dony1131 View Post
    2 of 3 reported will be fixed with next client update (no release date yet)
    The problem you have with the license dialog is nothing we could reproduce so far.
    September 2017
    47
    ok, thanks
    18,144
    Re "To your self deleted post"
    I wanted to reply to your first Android 3.1.8 report, but you did delete that post. So i would reply to nothing.
    Re "to your duplicate threads"
    The creation of multiple double threads will not fix your issue :/
    Duplicates will be merged or deleted. I merged one duplicate and deleted the others.
    Back to your original "cancel" problem:
    You updated to the 3.1.8 beta and this client does not represent the final stable 3.1.8 version.
    And please do not escalate this bug like pushing the cancel button is all you do all day long
    September 2017
    47
    Hello Dante...
    I deleted the post before, to create it in the "Bug Report" section and not in "Android", Sorry...
    So you're telling me that version 3.1.8 which and output on Android yesterday, and a beta, and not yet stable?
    However, now another App Problem has appeared, it doesn't make me count to any server, as soon as you know, it completely blocks the whole app, and the Android error message appears:
    "The Teamspeak yes and stop application" or "The Teamspeak application continues to stop".
    Which is the problem?
    Thanks
    18,144
    Yes you seem to be in a beta channel, because the 3.1.8 version was released as a beta.
    I have no clue about the connection problem.
    Which device and Android version are you using?
    September 2017
    47
    Hi Dante, thank you for your reply.
    As a phone I use LG K10 2017, and I have Android 7.0 Nougat.
    But the point and that these problems did not exist, when I had the 3.1.6 version of Teamspeak... and from version 3.1.7, which all appeared Problems Style. Now with version 3.18, have been fixed 2 bugs that were there with the 3.1.7, but have appeared others...
    As for the Concession Problem I find now, and that when I try to construct a server, the app completely crashes... I have already tried to clean the chache, restart the phone etc, but nothing changes... until last night... the app worked perfectly, beyond that bug of the "Cancel", which I had reported.
    Thank you
    18,144
    We have no clue yet why this is happening. We are elevating this freeze.
    Please be so kind and unsubscribe from the Android beta channel and install the stable client again.
    So you can use the client again and don't have to wait.
    This thread explains how to Subscribe/Unsubscribe from the beta.
    https://forum.teamspeak.com/threads/...p-Instructions
    But you need to uninstall the client to get the 3.1.7 again. and it could be that it takes a while till Google offers you the stable client again. Clearing App store cache may help here.
    September 2017
    47
    I tried to disscribe myself from beta, and it's true. Version 3.1.8 and beta. But as a stable version, does it give me the 3.1.6.1, and normal? therefore also 3.1.7 and beta?
    3.1.8 I see that it is unusable... is it not possible to move on to version 3.1.7? I really like design... at games from 3.1.7, and I also want to help as beta tester, to report bugs.
    Thanks
    18,144
    The normal update will bring you version 3.1.6.1.
    Beta version 3.1.7 was replaced with beta 3.1.8 and there is no way to select this versions.
    We are working on next 3.1.8 beta 3 and i will report back here, when we release a fixed version.
    September 2017
    47
    I hope that the next Beta, comes out as soon as possible, because the current beta 3.1.8 and unusable.
    Thank you
    18,144
    and unusable.
    That would be bad
    18,144
    A new 3.1.8 beta was released. This version handles the crash on connect.
    File transfers (like icon download) caused that.
    The Cancel button on connect is temporarily (or maybe permanent) disabled.
    September 2017
    47
    Yes, I have now installed the new beta, and works very well so far, the problem of crashing and solved.
    With regard to the "Cancel" button, is it permanently removed? and better to leave it, because if you have so many servers in the bookmark, and if you tap by mistake a random server, I can't delete the current conession.
    Thank you
  1. Update to RC1 problems
    By burnacid in forum Linux / FreeBSD
    Last Post: May 30th, 2011, 01:36 PM
  2. Sound Problems since the new Update
    By Reverant in forum Windows
    Last Post: May 13th, 2011, 08:03 AM
  3. MIc problems Since new update
    By Alrakis in forum Bug Reports [EN/DE]
    Last Post: May 13th, 2011, 06:04 AM
  4. Problems with new update
    By ricoboy23 in forum Bug Reports [EN/DE]
    Last Post: June 7th, 2010, 01:31 PM
  5. After Update from 22 to 23 Some little Problems
    By TSlein in forum Linux / FreeBSD
    Last Post: June 3rd, 2010, 09:53 PM
