Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: opus 1.2
    January 2018
    55
    opus 1.2
    17,798
    Update
    Original post is outdated
    Opus 1.2 can handle old and new CPUs and can detect which CPU is in use.
    It's still on our todo but there is no release date set.
    ----- Original post below -----
    We have this on our todo, but....
    Adding Opus 1.2 will need newer CPUs and this means our software will become more incompatible for users.
    There may be workarounds, but workaround often cause problems so...
    We are not sure when we are adding it.
    Please do not create a fourth Post/Thread for this.
    February 2018
    Serious question: Why will you need newer CPUs? What does this answer even mean? Discord has already added Opus 1.2. I prefer to use TeamSpeak over Discord, but come on, you're losing users to Discord because it sounds slightly better.
    Give users an option at least?
    17,798
    What I've heard from our devs was that Opus 1.2 needs CPU with "Streaming SIMD Extensions 3" (SSE3).
    Currently we still support when CPU instructions has at least SSE2.
    But as said there may be a workaround, but no release date for this. Workarounds are dirty and may cause more problems.
    April 2016
    This is a lie. Opus supports these instruction sets and also has run-time CPU detection, but it's optional. Sure... you can build Opus with several platform optimizations that will require SSE3, but this does not mean you have to. Your devs are wrong, which is very sad as they are working on a voice-communication software.
    January 2018
    55
    Opus 1.3
    Bitte bei teamspeak5 Opus updaten.
    17,798
    Opus 1.3 is not stable yet.
    January 2018
    55
    Yes, but it could be at the end oft the year.
    June 2018
    Poland
    75
    Opus voice
    That would be nice to see the new opus voice but if it will cause problems devs have to test it and then it should be available.
    March 2013
    localhost
    Why tho? Even on the Steam Hardware Survey, 100% of systems support SSE3 (Other Settings):
    https://store.steampowered.com/hwsur...lcome-to-Steam
    So the number of systems that don't support SSE3 and use TeamSpeak should be so low and it's neglectable.
    17,798
    Please ignore this and read post #2 instead.
    Opus has a detection and can handle older or newer CPUs.
    So which SEE we like to support doesn't matter anymore.
    November 2011
    Belarus
    141
    just want to inform you that 1.3 is out
    June 2018
    10
    Opus 1.3 stable was released on Oct. 18th so when will come up with it???
    February 2017
    Australia
    100
    Quote Originally Posted by edisonjwa View Post
    I read the blog post the other day, it's pretty great. Being able to get better quality from lower bitrates makes it great when roaming
    October 2016
    73
    An option for higher bitrates on Opus Voice would also be great.
    E.g. Make the Codec Settings go up to 12 or 15 to get like 10 or 12 KiB/s
  1. [Help?] Opus Voice > Opus Music!?
    By Vinni_ in forum Client Support
    Last Post: December 13th, 2014, 11:57 PM
  2. [Rejected] Opus 1.1, Opus Voice Stereo, Server-side smiles
    By KIDINK^ in forum Suggestions and Feedback
    Last Post: October 27th, 2014, 11:11 AM
  3. Opus 1.1 and SSL
    By Razilla in forum Suggestions and Feedback
    Last Post: August 8th, 2014, 03:32 PM
  4. Opus Codec
    By RadarGaming in forum General Questions
    Last Post: September 7th, 2013, 01:47 PM
