Results 1 to 10 of 10
    February 2018
    Client doesn't start (Failed to load ca certificates)
    my TS3 Client won't start on my Linux Mint installation.
    Distro: Linux Mint 18.3 Sylvia
    Kernel: 4.13.0-36-generic x86_64 (64 bit)
    Desktop: Cinnamon 3.6.7
    »openssl« is already the newest Version (1.0.2g-1ubuntu4.10).
    »ca-certificates« is already the newest Version (20170717~16.04.1).
    After running the ts3client_runscript.sh i got the following error
    [email protected] ~/TeamSpeak3-Client-linux_amd64 $ ./ts3client_runscript.sh
    QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
    I also get an Pop-Up saying:
    Failed to load ca certificates!
    Please install ca certificates on your system, or specify the location using the SSL_CERT_DIR or SSL_CERT_FILE environment variable.
    if also try to run it as sudo and also try to write the SSL Path manually in the runscript.sh file (/etc/ssl/certs and /usr/lib/ssl/certs) both not working.
    17,479
    The only error i see here is the red one.
    The message from QCoreApplication is no error and client should still work.
    My client starts without any problems on fresh installed Mint 18.3 x64 (Mate or Cinnamon) and i alos get this message from QCoreApplication.
    What you could try is to run following even when yours seem to be latest already.
    apt-get update
    apt-get install ca-certificates
    February 2018
    I've tried this already
    work TeamSpeak3-Client-linux_amd64 # apt-get update && apt-get dist-upgrade && apt-get install --reinstall ca-certificates openssl
    Ign:1 http://mirror.netcologne.de/linuxmint/packages sylvia InRelease
    OK:2 http://ftp.stw-bonn.de/ubuntu xenial InRelease
    OK:3 http://mirror.netcologne.de/linuxmint/packages sylvia Release
    OK:4 http://ftp.stw-bonn.de/ubuntu xenial-updates InRelease
    OK:5 http://security.ubuntu.com/ubuntu xenial-security InRelease
    OK:6 http://repository.spotify.com stable InRelease
    OK:7 http://ftp.stw-bonn.de/ubuntu xenial-backports InRelease
    Ign:8 http://repo.vivaldi.com/stable/deb stable InRelease
    OK:9 http://repo.vivaldi.com/stable/deb stable Release
    OK:10 http://archive.canonical.com/ubuntu xenial InRelease
    Paketlisten werden gelesen... Fertig
    Abhängigkeitsbaum wird aufgebaut.
    Statusinformationen werden eingelesen.... Fertig
    Paketaktualisierung (Upgrade) wird berechnet... Fertig
    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
    0 aktualisiert, 0 neu installiert, 2 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
    Es müssen noch 0 B von 659 kB an Archiven heruntergeladen werden.
    Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
    Vorkonfiguration der Pakete ...
    (Lese Datenbank ... 602280 Dateien und Verzeichnisse sind derzeit installiert.)
    Vorbereitung zum Entpacken von .../ca-certificates_20170717~16.04.1_all.deb ...
    Entpacken von ca-certificates (20170717~16.04.1) über (20170717~16.04.1) ...
    Vorbereitung zum Entpacken von .../openssl_1.0.2g-1ubuntu4.10_amd64.deb ...
    Entpacken von openssl (1.0.2g-1ubuntu4.10) über (1.0.2g-1ubuntu4.10) ...
    Trigger für man-db (2.7.5-1) werden verarbeitet ...
    openssl (1.0.2g-1ubuntu4.10) wird eingerichtet ...
    ca-certificates (20170717~16.04.1) wird eingerichtet ...
    Trigger für ca-certificates (20170717~16.04.1) werden verarbeitet ...
    Updating certificates in /etc/ssl/certs...
    0 added, 0 removed; done.
    Running hooks in /etc/ca-certificates/update.d...
    done.
    done.
    And even then i got the Error that the ca-certificates are missing. I was check /usr/lib/ssl exist and has linked Directorys to "certs" and "private" located at /etc/ssl/ the only file i won't find is the cert.pem on my system.
    March 2018
    Quote Originally Posted by sancron View Post
    Same problem for me after updating to 3.1.8 on Ubuntu 16.04 Mate OpenSSL 1.0.2g
    Workaround: the file cert.pem would be /etc/ssl/certs/ca-certificates.crt on my system so just set the variable SSL_CERT_FILE to that file or change the script
    if [ -f "/etc/ssl/certs/ca-certificates.crt" ]
      then
        #Use this file
        export SSL_CERT_FILE=/etc/ssl/certs/ca-certificates.crt
    instead of the cert.pem part.
    May 2018
    ubuntu 18.04 run problem
    hi, is it an update for ts3 that haven't been released yet? bcuse I'm getting an error hvet i try to run the amd 64.run file. my system is updated but i get an error:
    Please install ca certficates on your system, or specify the loctaion using the SSL_CERT or SSL_CERT_FILE enviromment variable .
    I have updated and tried to install ca-certificates. but nothing works. any tips?
Name:	Skjermbilde fra 2018-05-03 17-02-18.png
Name:	Skjermbilde fra 2018-05-03 17-09-09.png
    6,044
    to run the client.
    May 2018
    still showing me the same message.
    March 2016
    26
    try outcommenting the SSL stuff in ts3client_runscript.sh
    I've to out comment it like below after each update,
    otherwise the SSL lib isn't found
    same happens on three other systems here
    #!/bin/bash
    cd "$(dirname "${BASH_SOURCE[0]}")"
    #If the bundled openssl is used, the app needs to find out where the CA certs
    #are located. This needs to be done with the help of openssl installed on the
    #system, before we include "." in the LD_LIBRARY_PATH.
    #First test if the bundled libssl is used
    #If bundeled libssl is used and SSL_CERT_FILE and SSL_CERT_DIR are not already set.
    #if [ -f "./libssl.so.1.0.0" -a -x "$(command -v openssl)" -a -z "${SSL_CERT_FILE+x}" -a -z "${SSL_CERT_DIR+x}" ]
    #then
      #Set them to sane defaults.
      #Get ssl dir according to system openssl
     # OPENSSL_DIR=`openssl version -d | grep -Po '(?<=\").*(?=\")'`
      #Is cert.pem located there?
      #if [ -f "${OPENSSL_DIR}/cert.pem" ]
     # then
        #Use this file
      #  export SSL_CERT_FILE=${OPENSSL_DIR}/cert.pem
      #Is certs dir located there?
    #   elif [ -d "${OPENSSL_DIR}/certs" ]
    #   then
    #     #Use this dir
    #     export SSL_CERT_DIR=${OPENSSL_DIR}/certs
    #   else
    #     #An unknown configuration was found. Or openssl/ca certificates were not
    #     #installed
    #     echo "Could not find CA certificates location"
    #     exit 3
    #   fi
    # fi
    export KDEDIRS=
    export KDEDIR=
    export QTDIR=.
    export QT_PLUGIN_PATH=.
    export LD_LIBRARY_PATH=".:$LD_LIBRARY_PATH"
    if [ -e ts3client_linux_x86 ]; then
    	./ts3client_linux_x86 [email protected]
    else
    	./ts3client_linux_amd64 [email protected]
    fi
    March 2016
    26
    Solved
    use the following ts3client_runscript.sh
    teamspeaks own startscript is broken in multiple places..
    you'll have to out comment the SSL stuff after every update, but this way it works:
    #!/bin/bash
    #then
     # OPENSSL_DIR=`openssl version -d | grep -Po '(?<=").*(?=")'`
     # then
        #Use this file
    #   then
    #     #Use this dir
    #   else
    #     #installed
    #     exit 3
    #   fi
    # fi
    export KDEDIRS=
    export KDEDIR=
    export QTDIR=.
    else
    fi
    May 2013
    I'm running into a problem with TS3 Client (latest ts3 linux x86 version) on Debian.
    QCoreApplication::applicationPath: Please instantiate the QApplication object first
    Error Message:
    I have set SSL_CERT_DIR environment variable to /etc/ssl/certs, to no avail.
    Also updating the ca-certificates package, as suggested in another thread, unfortunately does not help.
    Edit: Commenting out the lines works!
  1. Replies: 1
    Last Post: April 24th, 2017, 02:27 PM
  2. TS3 Client doesn't start
    By D3u577 in forum Windows
    Last Post: February 20th, 2010, 11:03 AM
