Results 1 to 5 of 5
    April 2018
    What's the best practice of using SDK asynchronously? (C#)
    I'm integrating TS3 SDK into my C#(WPF) project. I have tried several ways to use SDK asynchronously(Task, ThreadPool, etc) while I don't want to stuck UI process, but sometimes I got an InvalidOperationException. So I wonder if there is any sample code to do it right?
    Thanks.
    Hans
    6,080
    The C# SDK Wrapper Examples may be worth looking at if you haven't done so yet.
    April 2018
    I have already read example code, but it's a windows console project and all operations are finished on main thread. I need some codes about how to do these operations in multi-thread way.
    Thanks you for your reply.
    6,080
    The InvalidOperationExceptions you're getting are likely from your WPF code as the wrapper only throws that during initialization or when attempting to (dis)connect while a (dis)connect attempt in already in progress.
    Note that it is not guaranteed that an asynchronous operation resumes on the same thread it was called on.
    April 2018
    Yeah, I have read the code about checking source with Interlocked. So I tried to use task.ContinueWith(...). Then that exception did disappear, but I did't figure out if all operations are required to be done on a same thread or only connect/disconnect do.
    Thanks for your patience.
