Results 1 to 8 of 8
    May 2018
    Another Problem with QCoreApplication
    So quite a few people have reported issues with this before, so here is mine:
    When trying to launch TeamSpeak (3.1.9), I am greeted with this:
    /opt/teamspeak$ ./ts3client_runscript.sh
    QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
    I've already tried reinstalling Teamspeak as well as removing ~/.ts3client - both doesn't make any difference whatsoever.
    What can I do to get all of this back running?
    For reference:
    I'm on Ubuntu 18.04 right now
    17,479
    Is this really all you see in the console and there is nothing about OpenGL or Failed to CA Certificates?
    Because this message is nothing that prevents the client from starting.
    May 2018
    I have the same problem and tried the same things...
    I've also tried to reinstall the QT5 Libs..
    OS: Manjaro / ArchLinux
    The first Time I could start Teamspeak..
    17,479
    Same question counts for you.
    May 2018
    Ok.. it's only the one message and the Teamspeak3-Client is NOT starting...
    No OpenGL, No CA Certificates..
    6,044
    That message is normal, it's about the first thing that you see on every client start well not normal but... it is for the client...
    It shouldn't (and in our experience doesn't) prevent the client from starting.
    What prevents the client from starting is a different issue and you should check the log files, which can be found in ~/.ts3client/logs
    Please post the entire client log (the latest file in said directory).
    May 2018
    It was the only message for me as well.
    But I got it fixed. Just removed the client entirely, installed 3.1.8 then updated to 3.1.9 without any significant problems. So sadly I'm not able to reproduce the issue anymore.
    17,479
    Good that you could solve it.
    Sad that we have no clue what happened there ;(
  1. Serveredit problem, and Admin user problem.
    By 0wn3r in forum Linux / FreeBSD
    Last Post: December 23rd, 2018, 01:09 PM
