Results 1 to 2 of 2
    January 2011
    TS3 Client volume reduced when other app using device goes active
    Running TS3 v 3.1.10 - updated on 09 June, 2018
    on
    Windows 10 with update KB34284835, updated on 20 June, 2018
    Using a common output device (headphones) for several applications (Windows sounds, P3d, TS3,vLSO)
    When another application outputs to the device, it causes the output level (volume?) on TS to reduce way down to barely audible. After a period of inactivity, the TS3 volume returns to the preset level.
    It seems the "priority" of TS3 is such that it "yields" to other applications.
    Any idea how to prevent this from happening (have TS3 tell Windows to keep it's output volume set)?
    Thanks
    Al
    September 2019
    I'm having the same problem. Today FSXSE and P3D began muting Teamspeak anytime I'm in flight. However if I pause the flight or go into the options menu the Teamspeak volume returns to normal. I have already ran TS as administrator, the flight sim is running as administrator, and I have checked do nothing in the communications sound settings.
  1. Teamspeak volume and other app volume reduced
    By alludoisdie in forum macOS
    Last Post: July 26th, 2017, 11:53 PM
  2. Replies: 1
    Last Post: July 31st, 2016, 10:50 PM
  3. Camera in use when TS-Client is active
    By jimboberlin in forum Windows
    Last Post: July 27th, 2015, 02:07 PM
  4. Replies: 0
    Last Post: December 28th, 2014, 08:13 PM
