Results 1 to 3 of 3
    July 2018
    Dessau,Germany
    46
    TS-CMS.EU presents TSI (Teamspeak-Interface)
    Multi-functional web interface, including installer, for managing Teamspeak 3 instances, based on the TeamSpeak 3 PHP Framework with role and user management to customize and customize the UI for customers, co-administrators or other groups.
    System requirements (minimum / recommended)
    Basically, the TSI runs on Linux as well as Windows-based servers.
    However, my recommendation is Ubuntu from version 14.04.5 LTS.
    - CPU 2 Cores / 4 Cores
    - RAM 128 / 512 MB
    - HDD / SSD
    - PHP 7.0
    - MySQLi 5.0^
    - Max Execution Time 30 / 60 Sekunden
    - Max Input Time 60 / 120 Sekunden
    - Post Max Size 8 / 16 MB
    - Upload Max Filesize 8 / 16 MB
    - Allow Url Fopen, Safe Mode Off, File Uploads
    - PHP Extensions: Zip, Curl, Zlib, BC Math, XML
    - Licensing and operation only under valid domain or subdomain possible
    - Browser: Mozilla Firefox from version 58.0.1 (64-bit) / Google Chrome from version 63.0.3239.132 (official build) (64-bit)
    - Screen resolution: 1768x992 / 1920x1080
    - Internet connection required
    Screenshots:
    Features:
    Multifunctional control center
    Intelligent multilingualism
    Modular extensibility
    Presentation individually customizable
    Manage Teamspeak³ instances
    Manage Teamspeak³ server
    Management of templates
    Extensive statistics
    Server Interface & TS Explorer
    Manage server groups (extension)
    Manage channel groups (extension)
    Manage users & rights (extension)
    Manage files & icons (extension)
    Teamspeak³ Bot (extension)
    Cronjobs (Ajax / Webron / Crontab)
    API interface (extension)
    More - Coming soon
    You need more informations so visit us on
    TS-CMS Website
    July 2018
    Dessau,Germany
    46
    Here is a small outlook on possible features whose implementation is planned after the summer break.
    Migration of the note system into the database
    Implementation of the note system in the module server groups, channel groups and clients
    Optimization of the TS Explorer in all areas (drag & drop, functionality, presentation, performance, etc.)
    Function for configuring dynamic host banners
    Implementation of a control for SinusBots
    Implementation of a time-based leveling system for the module SimpleBots
    Implementation of a DNS control (TSNDS)
    Coming soon in SimpleBots beta:
    myTeamSpeak ID Checker / Kick function inspired by @SossenSystems
    TSI Main System 1.0.41 BETA via package server available
    Note: Please note that the beta versions are not intended for productive use, but only for preliminary testing. If a beta version is still installed via the package server, you have to expect that serious errors will occur or that data will be lost forever. The use of beta versions is therefore at your own risk!
    TSI Main System Changelog:
    ! Complete support and compatibility of the functions of the Main System implemented for TeaSpeak server by @WolverinDEV
    (The adaptation of all extension modules will follow step by step in the next few days ..)
    ! It is recommended that TeamSpeak servers be upgraded to 3.2.0 (build> = 1525708231)
    The performance and speed of Query Query has been significantly improved
    Query connections using the IPv6 address are now supported
    Fixed an issue that caused Hostbanner to generate bad paths
    Updated Pact Dependencies:
    Symfony / Debug (v3.4.11 => v3.4.12)
    Symfony / Console (v3.4.11 => v3.4.12)
    Modules Clients 1.0.4 BETA, Servergroups 1.0.3 BETA & Serverfiles 1.0.3 BETA Changelog:
    The corresponding modules are now compatible with TeaSpeak Server
    I also want to encourage everyone to share their ideas here, if they want, no matter what they are.
    As you know, I am always open for everything
    July 2018
    Dessau,Germany
    46
    TSI Main System 1.0.46 BETA Changelog:
    From now on music bots can be created in the TS Explorer via the channel context menu (only for TeaSpeak Server)
    Music bots can now be controlled via server interface (only for TeaSpeak server)
    The following permissions have been added to role management
    tsi_virtualserver_music_bot_create
    tsi_virtualserver_music_bot_delete
    tsi_virtualserver_music_bot_queue_add
    tsi_virtualserver_music_bot_action
    tsi_virtualserver_music_bot_queue_rem
    tsi_virtualserver_music_bot_player
    An error has been fixed which led to the message "Undefined variable: btruns" in the server interface
  1. TeamSpeak 3 server lag interface | Ubuntu 16.04
    By Lafa02 in forum Linux / FreeBSD
    Last Post: June 9th, 2018, 11:12 AM
  2. Administrative TeamSpeak 3 Web interface, old something I made
    By Quincidence in forum Tools / Web Based
    Last Post: July 10th, 2017, 01:05 PM
  3. Teamspeak 3 Web Interface [HELP]
    By dazholmes in forum Server Support
    Last Post: May 25th, 2016, 12:11 PM
